Post by jollyr6 on Jul 7, 2018 11:10:33 GMT 1
Im running a 12a carb on my 125lc but have a 10w carb i want to put on my 12a is running a 220 jet as i have a micron on question is what do i put in the 10w as it only runs a 150 jet as standard and a 12a carb runs a 180 standard jet i think confused.com thought the 10w would run a bigger standard jet tia JOLLY
Post by broughton on Jul 7, 2018 18:00:46 GMT 1
155 standard on the 10w mate you wud need to upjet to a170 with that micron on but i wud put money on it that it will make hardly any difference in the power delivery the restriction is in the pipes ive tried different carbs on mine only difference was with the mid range splutter just before you go into the bandone carb had it the other was fine absoulutley no difference at all top and btm end and by the way its a 195 standard on the 12a dont mess with it its running fine.
