eddiekidd
Just had a go firt kick started right up and ran on both cycinders briefly and wiht a ilttle trottle
Post by eddiekidd on May 31, 2018 22:13:49 GMT 1
Hi Lads, I have a problem with my 350b running like the power of a 125 but sometime it runs good for a few seconds its as if its starving for fuel. I just had the carbs cleaned its on standard pipes and jets. I took it out for a spin this afternoon and noticed a backfire, I drove it back home and but it on the high stand ran it up and down the gears and in 6th gear it backfired a few times next thing it started revving full wack on its own I hit the kill switch and turned off the key to no avail next thing it cut out and wont start but if I kick it over a few times fast it back fires a bit but no start any help would be appreciated. Regards Eddie. UPDATE////////////// just went back to the bike after it cooled down for an hour and first kick it started perfect but running briefly on both cylinders and by giving a little throttle it runs intermittently on both at approx 2500 revs . I turned it off again and when I started it again it revved out full speed again by its self shut it down again and again it wont start for me. Can any body help
Post by sispeed on Jun 1, 2018 11:56:59 GMT 1
You write cleaned the carbs. Float bowls swapped? Throttle bodies swapped? Regards Siggi
eddiekidd
Post by eddiekidd on Jun 1, 2018 14:47:12 GMT 1
Hi siggi thanks for your reply. yes had the carbs professionally done. It started perfect this morning on both cylinders when cold but under load or when it starts to heat it goes intermittent on the second cylinder again, I'm think it may be a fuel supply to the second carb or a electrical fault.
Post by reedpete on Jun 1, 2018 19:06:20 GMT 1
What colour is the plug on the dodgy side. If it’s fuel starvation it’s going to be bone dry and pale but if it’s spark problem then you’d expect it to be wet.
Post by reedpete on Jun 1, 2018 19:07:53 GMT 1
You’ll need to do a plug chop by cutting engine and coasting with clutch in to catch the condition. No point riding home and idle for a bit before you check.
Post by sispeed on Jun 5, 2018 11:19:31 GMT 1
If problem starts when bike warm, I would point at the ignition and especial on the coils
Post by jonboy on Aug 30, 2018 14:22:21 GMT 1
it is worth checking that the rectifier and regulator has no bad connections.. I worked on a 250 points model years ago which would drop on to one cylinder intermittently and then would suddenly chime in on two and then drop off again etc... it had a bad connection on the rectifier. sorting that connection sorted the issue... might not be that, but it is one to look out for. if its an electronic model, it won't have any effect as they will run with no battery or reg/rec
Post by beardy on Sept 3, 2018 7:13:37 GMT 1
your issue has some similarities to an issue i`ve recently had with my 350lc. get an avo and check your hi and lo readings on the stator. my readings were not as standard but it sometimes ran ok and at other times cut out and backfired. i`ve had the stator rewound and it appears to have fixed it.
Post by madmick on Dec 27, 2018 13:45:41 GMT 1
Had exactly the same problem with my lc2... turned out to be the cdi. I would say you have electrical gremlins. Go down that route.
M.M.
Post by stuzx4r on Dec 28, 2018 15:11:18 GMT 1
Hi, the most likely cause would be condensers (and/or points), a defective condenser will very often work initially but will start to break down after being run for a while this leads to an erratic arcing at the points and an untimely spark at the plug creating a backfire. Both items are relatively cheap to buy thankfully.
Good luck.
Post by copper99 on Dec 29, 2018 16:27:08 GMT 1
Start with the cheap stuff and go from there mate, for what its worth, when LC started back firing and mucking around last year, main cause was the stator.
