Post by ypvs400 on May 24, 2018 13:27:45 GMT 1
Any idea how to asdjust the head bearings when using Mito forks ? I know it sounds daft but no external thread on the steering tube and no clamp on the top yoke where it fits over the steering tube.
Post by ypvs400 on May 24, 2018 19:32:29 GMT 1
Not so daft after all then
Post by russpuss on May 24, 2018 19:36:51 GMT 1
I’ve Mito forks in my X7, made my own stem but doesn’t a bolt fit in the top of the stem and you tighten it?
Post by ypvs400 on May 24, 2018 20:14:20 GMT 1
I’ve Mito forks in my X7, made my own stem but doesn’t a bolt fit in the top of the stem and you tighten it? Just a large diameter bolt in the top of the stem going in into the internal thread but no clear way to adjust the head bearings .
Post by russpuss on May 24, 2018 20:27:49 GMT 1
I’ve Mito forks in my X7, made my own stem but doesn’t a bolt fit in the top of the stem and you tighten it? Just a large diameter bolt in the top of the stem going in into the internal thread but no clear way to adjust the head bearings . Not sure then as I made my own stem to fit when I tighten my bolt it pulls the roller bearings tight.
Post by ypvs400 on May 24, 2018 20:34:22 GMT 1
So how do you adjust the free play and lock the adjustment ?
Post by russpuss on May 24, 2018 20:36:03 GMT 1
So how do you adjust the free play and lock the adjustment ? I made my stem sit lower than the yolk so when nipped up it takes the free play. On Facebook there’s a mito page, worth a join and ask?
Post by ypvs400 on May 24, 2018 20:51:35 GMT 1
So how do you adjust the free play and lock the adjustment ? I made my stem sit lower than the yolk so when nipped up it takes the free play. On Facebook there’s a mito page, worth a join and ask? Thanks for the reply but I dont do Facecloth, the only time you can fully tighten a ventre bolt with taper rollers is if you have a sleeve between the two inner races or like a car wheel bearing when the innner races touch, any other way will over thghten the bearings and damage the tracks plus give pretty poor handling.
Post by russpuss on May 24, 2018 21:00:24 GMT 1
I made my stem sit lower than the yolk so when nipped up it takes the free play. On Facebook there’s a mito page, worth a join and ask? Thanks for the reply but I dont do Facecloth, the only time you can fully tighten a ventre bolt with taper rollers is if you have a sleeve between the two inner races or like a car wheel bearing when the innner races touch, any other way will over thghten the bearings and damage the tracks plus give pretty poor handling. That’s mine, just slightly less than the yoke so when tight just right.
