Post by andysh2 on May 5, 2018 22:18:27 GMT 1
Hi all just rebuilding my Mk2 RD125LC and the 12a carb I have has an unthreaded carb top where the throttle cable goes all the adjusters I have found have either have a 6mm or 7mm thread. Not sure what should be in the top???
Post by graeme6 on May 6, 2018 19:31:56 GMT 1
Mine has no threads, cable is a snug push fit held in place by a circlip. Once the nipple on the cable is threaded into the carb slide the spring and cover prevent it from being able to come out. Don't even need to fit the circlip if you do not have one.
Post by andysh2 on May 6, 2018 22:09:26 GMT 1
Hi I've had a sort out today and found an old throttle cable with the correct end on phew lol just need to sort the c clip then it's good to go spent ages looking online as I wasn't sure what I needed :-)
Post by graeme6 on May 7, 2018 13:14:57 GMT 1
Don't really need the clip as the spring keeps it fastened to the slide, actually a bit tricky to get it off.
