Choke
Mar 9, 2018 0:10:20 GMT 1
Post by 125lc1dt on Mar 9, 2018 0:10:20 GMT 1
How do you determine if the Choke Plunger assembly on the Mukuni carb is worn / faulty ?
Choke
Mar 9, 2018 20:22:52 GMT 1
via mobile
zig likes this
Post by midlifecrisisrd on Mar 9, 2018 20:22:52 GMT 1
See if you can blow through the pick up from the float bowl with the plunger in
Choke
Mar 10, 2018 13:42:58 GMT 1
Post by 125lc1dt on Mar 10, 2018 13:42:58 GMT 1
Okay. Also is there an O ring fitted to to threaded part on these ?
Choke
Mar 10, 2018 17:47:13 GMT 1
via mobile
Post by midlifecrisisrd on Mar 10, 2018 17:47:13 GMT 1
From memory no
Choke
Mar 19, 2018 22:39:32 GMT 1
via mobile
Post by peter007 on Mar 19, 2018 22:39:32 GMT 1
When you say pick up from the float bowl what do you mean exactly ? The overflow ?
Choke
Mar 20, 2018 18:51:40 GMT 1
via mobile
Post by midlifecrisisrd on Mar 20, 2018 18:51:40 GMT 1
When you say pick up from the float bowl what do you mean exactly ? The overflow ? It is inside the carb. Goes from the main body into the float bowl Steve
