Post by sknippen on Feb 12, 2018 12:38:12 GMT 1
Hello All,
I am new here.
I recently bought a '77 Yamaha RD 125 DX. It is in a overall good condition and has low mileage. But with checkup i noticed that the oil pump is leaking. I plan to repair the pump (or send it for repair), but i the meanwhile i will run on premix. Is it ok for a RD to run on premix and what ratio oil/fuel i should use?
Thanks in advance,
Sonny
Post by earthman on Feb 12, 2018 13:36:32 GMT 1
The ratio aspect is a bit of a minefield, I've seen the following quoted on here, 25:1 30:1 35:1 and 40:1
I recently run my 350LC on 25:1, just for a short time, to check that oil were actually getting through to both carbs.
Post by markhoopy on Feb 12, 2018 19:01:44 GMT 1
Post by Ozhammer on Feb 12, 2018 22:44:21 GMT 1
Send your pump to Arrow and get it back better than new.
If running premix, you are likely to need to re-jet your carbs.
HTH
Post by arrow on Feb 22, 2018 0:36:09 GMT 1
If you run on premix even for a short time you will need to remove the oil pump wormshaft and blank off the hole.
