Post by fatfreddy on Jan 15, 2018 23:10:30 GMT 1
When I failed in my efforts to bleed my front brake, I took the master cylinder apart and found it all gummed up and nasty. There seems to be a bit of corrosion at the bottom of the bore but what I don't know is if this means I should be ordering a new master cylinder rather than a rebuild kit.
Any advice appreciated!
Post by ypvs400 on Jan 16, 2018 8:36:39 GMT 1
It depends on the extent of the corrosion, see if it will clean up with some 800 wet/dry wrapped around some wooden dowel or buy a fine stone small cylinder hone to use in a drill, if it cleans up quickly leaving no pitting you will be OK.
Post by fatfreddy on Jan 16, 2018 8:40:11 GMT 1
I’ll give that a try. Cheers!
