Post by budgie on Nov 29, 2017 22:05:26 GMT 1
Hi Guys, looking for some advice, my latest project is a 250e rolling chassis that I have bought from a forum member that I am turning into a race bike.... I need a bit of info in respect of rear sets... what fits and will work without too much modification, and feel comfortable for a 5ft 10 guy , the bike is currently fitted with a race seat....I have seen the Raask ones, but to be fair, thought they may be OK on a road bike, but maybe not a race bike.....just looking to see what all you race Guys are using... all advice welcome.
cheers
Gav
Post by donkeychomp on Dec 16, 2017 0:53:01 GMT 1
I've made 2 RD250 race bikes in the past. On both occasions I used Kawasaki ZXR400 foot rests. You need to make one small bracket for each side, including one to hold the brake fluid cylinder, but they worked a treat.
Post by budgie on Dec 16, 2017 8:18:24 GMT 1
Hi Alex
Thanks for the info, I have been looking at several options, but most are as you suggest, a small bracket required....which is not a problem... someone has also suggested that a Honda RC24 footrests bolt straight on, so just trying to get someone to measure some for me...but I think the easiest solution will be some simple brackets...thanks for the reply, I will have a look at them...
Gavin
Post by donkeychomp on Dec 20, 2017 23:40:39 GMT 1
Just recalled another reason I used the ZXR ones. The rear brake cylinder is incorporated into the foot rest itself so saves on more bracket making/hole drilling!
Post by budgie on Dec 21, 2017 11:02:34 GMT 1
Just recalled another reason I used the ZXR ones. The rear brake cylinder is incorporated into the foot rest itself so saves on more bracket making/hole drilling! Alex Thanks Alex, I had thought the same....! Gavin
Post by guiri on Jan 1, 2018 12:33:39 GMT 1
yes, i used early honda vfr750 on my rd250e race bike. right side straight fit. left side needs a bracket. will post you some fotos when i get a mo. john.
Post by budgie on Jan 1, 2018 17:49:29 GMT 1
That would be really helpful... Look forward to seeing them...
Gav
