Post by Deleted on Nov 11, 2017 21:10:19 GMT 1
In the Haynes manual it states timing should be 2.3mm, but I have read that due to the octane quality of today's fuel compared with the'good stuff' of the 1970's timing should be 1.8mm. Anyone any advice?
Post by Ozhammer on Nov 12, 2017 0:43:24 GMT 1
Just to be clear Penno, are you asking about a Euro/UK spec F model (2R9 engine with CDI) of the US points (2V0) model?
I can’t comment on the 2V0 settings but if you have a 2R9 model engine, my understanding was that the manual figure is 2mm BTDC, although some folk reckon that 1.8mm is better suited to faster burning modern fuel.
I run my bikes at 2mm and that seems fine with 98 RON fuel.
HTH
Post by Deleted on Nov 12, 2017 8:45:23 GMT 1
Hello Ozhammer, yes it is a UK model I recently purchased and want to ensure the timing is spot on. Thanks for your advice
Post by oldelsieboy on Nov 12, 2017 9:08:28 GMT 1
In the Haynes manual it states timing should be 2.3mm, but I have read that due to the octane quality of today's fuel compared with the'good stuff' of the 1970's timing should be 1.8mm. Anyone any advice? I'm sure the guys on the Aircooled Club forum will have the answer. www.aircooledrdclub.com/smf/index.phpOEB
Post by reedpete on Nov 16, 2017 7:30:13 GMT 1
Absolutely not 1.8....that’s 250/350 territory. 2.0 probably on the money...as it was back then actually just the topic attracts a lot of ‘knowledgable’ people.
Post by Deleted on Nov 16, 2017 11:50:52 GMT 1
I am going for 2.0 reedpete. I have been on the air cooled forum and this seems to be the recommended measure. Thanks for your support
