Post by donkeychomp on Apr 23, 2024 21:09:39 GMT 1
Mouse came over earlier today and I'm very glad he did. We have come to the conclusion it is the right drive but it's missing a component. There's a washer with 2 tangs that sit between the drive and the wheel in order for the thing to rotate properly and thankfully there was 1 on eBay. Ordered, should be here on Friday.
Post by oldbritguy on Apr 25, 2024 22:39:11 GMT 1
Sometimes all it needs is a fresh pair of eyes and a bit of detective work. Good work. I hope you made Mouse a brew (and with a biscuit of course)
Post by donkeychomp on Apr 25, 2024 23:30:11 GMT 1
His usual coffee. I neglected to offer a biscuit as I don't buy them. Schoolboy error.
Post by dusty350 on Apr 26, 2024 7:16:35 GMT 1
A "Haribo" platter is what you should provide Mouse. The "Breakfast of Kings" apparently
Post by stusco on Apr 26, 2024 7:38:55 GMT 1
Haribo gives me goutโน๏ธ
Post by donkeychomp on Apr 26, 2024 21:11:42 GMT 1
Are you confusing Haribo with 8 pints of Guinness?
Post by midlifecrisisrd on Apr 26, 2024 23:13:40 GMT 1
Are you confusing Haribo with 8 pints of Guinness? Alex Oh jeez ๐ That's where my mother went wrong ๐ฅด Steve ๐คฃ
Post by donkeychomp on Apr 29, 2024 21:06:44 GMT 1
Post by oldbritguy on Apr 29, 2024 21:42:01 GMT 1
And we have a roller.
Good to see Dustyโs bench filling up nicely too.
Getting there Alex
John
Post by donkeychomp on Apr 29, 2024 22:28:56 GMT 1
Cheers John. Yep, the Busty Dench is proving invaluable!
Post by JonW on Apr 29, 2024 23:57:04 GMT 1
excellent!
Post by mouse on Apr 30, 2024 6:21:26 GMT 1
Now that's progress!
Mouse
Post by dusty350 on Apr 30, 2024 6:35:30 GMT 1
Looking great mate
Post by donkeychomp on May 1, 2024 21:07:31 GMT 1
Carried on today. Thought I'd better fit the horn bracket Al made for me before I did the headlight. On the Mito forks there is only one hole drilled on the yoke, for the speedo cable guide, so I drilled another. On goes the new horns, wasn't sure of the position I wanted them to be at first. But the with the headlight in place they need to be at a more jaunty angle... Not like this as they'd smash into the mudguard! And ended up plonking the clocks on. Alex
Post by midlifecrisisrd on May 1, 2024 21:32:57 GMT 1
Making good progress now ๐
Will an LC horn bracket and cover not bolt to Al's bracket?
Strve
Post by dusty350 on May 1, 2024 21:39:01 GMT 1
Will the horns not hit the front muddie when the forks depress ? ( last pic with them hanging in the "6 o clock" position)
Post by donkeychomp on May 1, 2024 22:11:40 GMT 1
A) Don't know mate.
B) Yes they will Dusty but I'll figure something out.
Post by donkeychomp on May 1, 2024 22:16:41 GMT 1
Looking at it again I think I might have the bracket on upside down...I'll have another go tomorrow.
Post by dusty350 on May 2, 2024 7:16:07 GMT 1
Morning mate The standard Lc "way" is they stick out sideways; 20180301_160209 by dusty miller, on Flickr I think they look great mounted that way, and if they can sit higher and nearer to the headlight they wont look out of place, imo
Post by stusco on May 2, 2024 7:44:47 GMT 1
Are you confusing Haribo with 8 pints of Guinness? Alex Could be I always got gout when on holiday so itโs either the haribo eaten on the road trip or the bevy when on holiday
Post by donkeychomp on May 2, 2024 20:50:08 GMT 1
Turned the bracket over... One thing puzzles me. Why is there only one bolt holding each horn on? Does everyone use Loctite? Also made a start on a infill panel to house some electrics... Alex
Post by midlifecrisisrd on May 2, 2024 21:08:44 GMT 1
If you look at the horn brackets there is one bolt hole and a small locating notch on the edge of the bracket that locates onto a small pin
I'd see if an lc bracket goes on Al's mount as it would allow you to fit a horn bracket too which is another LC identifying item
Post by donkeychomp on May 2, 2024 21:57:24 GMT 1
Thanks Steve. Something I need to look into. That or super glue lol.
Post by JonW on May 3, 2024 0:28:15 GMT 1
The horn bracket has turned edges (solid on one edge, just partial on the other) that create a solid recess that the horn bracket sits in when its bolted on. Its well worth dropping him a line and asking, but I would expect that Al made his mount to hold the OEM bracket. Get the bracket and a cover and it'll look much more '350 LC'.
Post by midlifecrisisrd on May 3, 2024 7:37:49 GMT 1
The horn bracket has turned edges (solid on one edge, just partial on the other) that create a solid recess that the horn bracket sits in when its bolted on. Its well worth dropping him a line and asking, but I would expect that Al made his mount to hold the OEM bracket. Get the bracket and a cover and it'll look much more '350 LC'. Ah, I'm getting mixed up with LC2 Steve ๐คก
Post by sidney81 on May 3, 2024 10:17:29 GMT 1
Looking good Alex ๐
Post by donkeychomp on May 5, 2024 21:18:49 GMT 1
Thought I'd fit that speedo drive tang today. Managed to heft the beastie back on the stand. Wheel out, tang and dust cover in. Then removed the stand and went inside. Then it dawned on me I should have left it on the bloody stand and checked if the speedo worked! Dammit. I'll do that tomorrow. Next job is to fit the engine. This is so close now I can smell the 2 stroke. Alex
Post by JonW on May 6, 2024 0:17:07 GMT 1
pic of this part and how it fits?
Post by dusty350 on May 6, 2024 7:07:34 GMT 1
Good news mate. And leave it on the stand for engine fitment. Much better to fit the engine with the bike level. Unless you have a paddock stand ?
๐
Post by donkeychomp on May 6, 2024 21:35:05 GMT 1
Sorry Jon I didn't get a pic.
I have a paddock stand Dusty but I'll leave her on the wooden one for now.
