Post by dusty350 on Mar 16, 2018 9:18:58 GMT 1
Beautiful looking bike Dusty
Post by sarnia1 on Mar 16, 2018 11:08:44 GMT 1
whats the top yoke from.
Post by Mr Kipling on Mar 16, 2018 11:21:17 GMT 1
Top yoke is billet item made for the R6 Yam...
Post by sarnia1 on Mar 16, 2018 11:46:33 GMT 1
ok cool thanks .As i didn't think you could get a rs mk1 billet yoke with the offset ignition.nice build
Post by yamark on Mar 16, 2018 21:23:45 GMT 1
Very, very nice. Keep up the good work
Mark
Post by tony1964 on Mar 16, 2018 23:14:30 GMT 1
Yet another very nice build.
Post by dereckerick on Mar 17, 2018 16:53:49 GMT 1
Post by mouse on Mar 20, 2018 9:53:53 GMT 1
This is looking great Mr K, You're like a whirling dervish once you get started! (I'm a bit confused as to which build is which, but i am a bit simple!)
Mouse
Post by Mr Kipling on Mar 20, 2018 15:14:07 GMT 1
This is looking great Mr K, You're like a whirling dervish once you get started! (I'm a bit confused as to which build is which, but i am a bit simple!) Mouse G,day Mouse , this be me used to be Fighter , turning into road come track day bike ( body permitting ) other build will end up similar too how this one started.. Really tempted too bung in full Nova box as Brands n Cadwell dates are rapidly approaching an me thumbs are twiddling with anticipation... (rofl) Also Picked up another set of waterpump gears these are 1.45 ratio Std Yam is 1.6 these will allow the pump too spin faster , should help keep the engine cooler , not sure where there going yet...
Post by Tobyjugs on Mar 28, 2018 16:14:57 GMT 1
Hi Mr kipling where did you get the non standard ratio gears from?
Post by Mr Kipling on Mar 28, 2018 16:22:34 GMT 1
Replied P.M
Post by yamark on Mar 28, 2018 17:30:06 GMT 1
Hi Mr K, same question as Tobyjugs.
TIA, Mark
Post by Mr Kipling on Mar 28, 2018 20:45:32 GMT 1
TIA, Mark Replied ...
Post by Mr Kipling on Mar 31, 2018 17:51:50 GMT 1
Had a little play today whipped off the complete rear end attached a unmodded arm replaced the rear wheel brake caliper etc for std set up had to fit a new goodridge line too match the fronts again.. Whipped the discs off the front wheel re attached too another n reslotted back into place ,had too order another rear disc n Ti bolts but all in all a appy bunny ... Wearing its new front hoop ...
Post by Mr Kipling on Apr 1, 2018 23:11:45 GMT 1
Overhauled a Half nova gearbox today refitted the gears with new circlips ( courtesy of Norbs Magical Emporium ) Sorted out rest of components ready for a bottom end re-build .Gonna be using the Nova Straight Cuts with the Barnett basket also.. Upping the CC on this one , I,ll let it unravel as I build it n document it..
Post by donkeychomp on Apr 1, 2018 23:44:49 GMT 1
Are you sure an ancient Vauxhall gearbox will work?
(sorry lol)
Post by Mr Kipling on Apr 2, 2018 0:36:08 GMT 1
Are you sure an ancient Vauxhall gearbox will work? (sorry lol) Alex LMAO almost choked n dropped the rest of me curly wurly in the bath... :P
Post by doohanno1 on Apr 2, 2018 0:39:43 GMT 1
Are you sure an ancient Vauxhall gearbox will work? (sorry lol) Alex Of Corsa it will, he's a Cavelier type of guy...
Post by Mr Kipling on Apr 2, 2018 21:48:58 GMT 1
Righty then just paid for the remaining parts for me new top end being sent express delivery (so I,m told ) looking forward too this now , means I can par down the wiring a bit an get the remainder re-attached as I got a direction too head in , still need inlets .H/D clutch n exhausts but were getting somewhere now... The new barrels and pistons on page one are not being used on this build anymore ,still rebuilding the original TZ,d lump as a back up plan, I,ll crack on with the race bodywork now get it drilled an any excess removed...Might need too rename the thread again ..Gonna eat a special bar of Choccy as time is running out an I need too get a move on !!!
Post by Mr Kipling on Apr 4, 2018 23:24:07 GMT 1
Righty then just paid for the remaining parts for me new top end being sent express delivery (so I,m told ) Just checked the tracking on these , scheduled delivery for the 10th !!!! if that's true I,ll be Well Appy Bunny :D
Post by donkeychomp on Apr 5, 2018 21:19:23 GMT 1
That is sweet. Are you putting a red sticker on the rear wheel too?
Post by Mr Kipling on Apr 5, 2018 21:28:41 GMT 1
That is sweet. Are you putting a red sticker on the rear wheel too? Alex That,ll prob come off at some point in exchange for yellow or something..
Post by 4l04ever on Apr 6, 2018 17:58:39 GMT 1
What is the BDK box for, as I thought the Zeel would do everything you need (ignition/powervalves/rev limiter etc)?
Post by Mr Kipling on Apr 6, 2018 18:41:11 GMT 1
Bdk box controls the voltage supply from the P/Fab rotor to the battery..
Post by Mr Kipling on Apr 7, 2018 19:43:46 GMT 1
Had another serious chat with myself today really want this bike sorted asap to ride , so thinking about popping Old Faithful back in albeit it,ll have a few diff parts added / removed.. Old Faithfull still quite a beauty...
Post by Tobyjugs on Apr 7, 2018 21:21:23 GMT 1
Hello Mr K, what type of throttle do you use with the PJ's
Post by Mr Kipling on Apr 7, 2018 21:50:14 GMT 1
Hello Mr K, what type of throttle do you use with the PJ's on these carbs I use a one off single pull conversion set up..
Post by Tobyjugs on Apr 7, 2018 21:52:09 GMT 1
Does that mean both carbs are mechanically linked?
Post by Mr Kipling on Apr 7, 2018 22:07:35 GMT 1
yeah n nah , there both connected by short cables too a pivoting cantilever plate system which I connected to my carb tops which is then pulled by a single venhill cable , so not mechanically linked as such but very different n effective ...
Post by Tobyjugs on Apr 7, 2018 22:12:03 GMT 1
I was thinking of a twin pull from the throttle for my PJ's
