Post by steve h on Oct 22, 2017 21:42:37 GMT 1
Steve H Have you used the Aspen fuel in your LC? Nope.....but it goes in my windy and rotavator, and multi tool. No trouble starting the rotavator anymore! Can only offer my experience with it.....not somebody else's hearsay.....The rotovator was a particular b*****d to start up every May. Now I just leave aspen in it all the time.....and in the time (3 yrs) that I've put aspen in it, it has fired up in 2 pulls of the cord with none of the swearing and threatening it with a lump hammer, stripping the carb, taking the plug out ect. (I'm sure it used to think it was a two stroke!!)
Post by bazzer5115 on Oct 22, 2017 22:22:08 GMT 1
Early 1050 speed triples had plastic tanks 2005-2008 I believe,triumph then changed to steel. Mine is 2006 which I bought new.Never had a problem until about 4 years ago,when the tank started "growing" Had to bend bracket on frame back to fit tank back on now. It's "grown" about 7mm to 8mm. Still looks good though,my mates Ducati tank is full of lumps and bumps!!!!
Post by rigga on Oct 22, 2017 22:31:18 GMT 1
Early 1050 speed triples had plastic tanks 2005-2008 I believe,triumph then changed to steel. Mine is 2006 which I bought new.Never had a problem until about 4 years ago,when the tank started "growing" Had to bend bracket on frame back to fit tank back on now. It's "grown" about 7mm to 8mm. Still looks good though,my mates Ducati tank is full of lumps and bumps!!!! Yup, like i said earlier, ethanol is crap with plastic tanks
Post by Flying fridge on Oct 23, 2017 18:10:20 GMT 1
I've just got some wurth fuel addative read an article in practical sportsbikes and they swore by it use it all year round, if bike is stood over winter this addative stops fuel going off
Post by Flying fridge on Oct 23, 2017 18:31:13 GMT 1
Sorry guys I fibbed it's in classic m/cycle mechanics issue 354 of April this year and it's called wurth fuel cure,in the same mag there's an advertisement on a similar product called star tron enzyme fuel treatment,would be interested if anyone else uses either of these
Post by midlifecrisisrd on Oct 23, 2017 18:39:30 GMT 1
Never tried it but I once heard that you should stick a half litre of surgical spirit in the tank
As it is soluble in water and petrol it solves the water absorbsion and then the ethanol going off and the water depositing
Probably bullshit
Post by Tobyjugs on Oct 23, 2017 23:11:44 GMT 1
Just a thought, what about using WD40 in the carbs?
Post by stevie632 on Sept 2, 2018 7:06:08 GMT 1
Has anyone tried "Seafoam". I have used this in my bikes for both cleaning the fuel system and as a fuel stabiliser. It can be used in two stroke, four stroke and diesel motors alike, and it says lawnmowers!! On Amazon it's £17+ per can but I did a Google search and found it for £6.99. Maybe worth a look.
oldgit
Post by oldgit on Sept 2, 2018 11:17:19 GMT 1
Always fill mine full with super unleaded, start them every now and then, never had a problem.
