Post by jollyr6 on Sept 28, 2017 17:46:09 GMT 1
Bought original head gasket but front n back of the top n bottom look like the glues come off don't want to use it n knacker it
Post by wonkywheel on Sept 28, 2017 19:13:15 GMT 1
Why not send it back, even if its NOS? If you got it from a show or job lot- then i would fit with clear silicone- start with no coolant for a while; torque down again- then add water/ or coolant and see how it goes . You have nothing to lose, especailly if the head is ok.
Post by jollyr6 on Sept 28, 2017 19:29:44 GMT 1
It's from fowlers n cost 50 quid if I put it on n it leaks I'm 50 down the swanny
Post by wonkywheel on Sept 28, 2017 19:53:23 GMT 1
From what I've been told, Yamaha put a sealant on the head gasket. When fitted and heat cycled, the sealant set and sealed. If it ain't there, send it back buddy- refund or repalcement. Fowlers should be cool- just be firm. On my rebuild I fitted many genuine vital engine parts, surprisingly I fitted a patern head gasket with clear silicone, still running fine. Just read your other thread- the majority of patern gaskest should be cool. Maybe check your cylinder head. Lots of forum member, keep the 4 barrel / cylinder nuts fairly loose when tightening down the cylinder head, as it allows the head gasket to seal better- then tighten the cylinder down. I'm not saying it works, yet i took forum advise and no leaks. . rdlccrazy.proboards.com/thread/35290/pattern-head-gasket-any-good
Post by jollyr6 on Sept 29, 2017 11:28:17 GMT 1
From what I've been told, Yamaha put a sealant on the head gasket. When fitted and heat cycled, the sealant set and sealed. If it ain't there, send it back buddy- refund or repalcement. Fowlers should be cool- just be firm. On my rebuild I fitted many genuine vital engine parts, surprisingly I fitted a patern head gasket with clear silicone, still running fine. Just read your other thread- the majority of patern gaskest should be cool. Maybe check your cylinder head. Lots of forum member, keep the 4 barrel / cylinder nuts fairly loose when tightening down the cylinder head, as it allows the head gasket to seal better- then tighten the cylinder down. I'm not saying it works, yet i took forum advise and no leaks. . rdlccrazy.proboards.com/thread/35290/pattern-head-gasket-any-goodoh no hope barrel not ferked only reason im changing is when i give it the beans water flowing into expansion bottle at a great rate of knotts ok upto 5 grand just when i beans it
Post by jollyr6 on Oct 2, 2017 9:11:25 GMT 1
Just a quick update all sorted now thanks for advise put nos headgasket on thin smear of hylomar heat cycled then cooled n retorqued went out on her saturday last 50 miles run in then gave it the beans n shes a flyer from 6k she pulls like a train happy days
Post by yamyzee on Dec 28, 2017 10:21:17 GMT 1
Sh#tcan the standard one and get a copper one off ebay......you can reuse it time again.you only have to heat it up cherry red to "anneal" copper and bring back its original properties.........seals better than anything else,reusable and cheap.whats not to like......? :-)
Post by earthman on Dec 28, 2017 10:50:35 GMT 1
Sh#tcan the standard one and get a copper one off ebay......you can reuse it time again.you only have to heat it up cherry red to "anneal" copper and bring back its original properties.........seals better than anything else,reusable and cheap.whats not to like......? :-) I've heard people doing that to copper sump plug washers too.
