Jet
Sept 17, 2017 16:43:19 GMT 1
Post by 125lc1dt on Sept 17, 2017 16:43:19 GMT 1
Hi the carb fitted to my 125 Lc1 is a Mukini VM 24 ss ( I believe) I've had it ultrasonic cleaned but it still has a initial flat spot. The Jet needle is slightly bent which I've sorted. I would like to remove the needle jet itself but not sure how. It looks like it drives back down into the base of the carb. Due to the rarity of these carbs I'm a bit reluctant to use any force on it ?
Jet
Sept 18, 2017 19:49:42 GMT 1
Post by 125lc1dt on Sept 18, 2017 19:49:42 GMT 1
Fitted a new Jet needle and the engine runs fine now. Will have to leave Jet needle for now
