Post by vic6169 on Sept 3, 2017 18:34:45 GMT 1
As the title says??
Post by 4l04ever on Sept 4, 2017 14:30:41 GMT 1
I think it is mainly some slight porting differences.
Post by midlifecrisisrd on Sept 6, 2017 20:45:19 GMT 1
As said porting only
Very slight
Post by aimdave123 on Sept 7, 2017 17:42:51 GMT 1
Can these barrels be interchanged. Thanks.
Post by midlifecrisisrd on Sept 7, 2017 18:33:41 GMT 1
As a pair yes
Would not be keen on a 31k on one and a 1ua on the other
Nothing to stop it actually working though
Post by jon on Sept 8, 2017 17:01:11 GMT 1
The power valves are also different to match the ports.
I think the 31k has a slightly lower exhaust port?
Post by Mr Kipling on Sept 8, 2017 19:25:44 GMT 1
All power valves same throughout the range only aftermarket billet valves address this , 1ua have higher ports 1mm from old memories n slightly wider , Yamaha originally done this to keep power output similar even though other changes didn't allow higher peak hp due to emissions police being on there case !!!. for those interested I can post up pics showing the difference between new 1ua barrels with standard valve n the other one with billet valve...
Post by bare on Dec 15, 2017 18:38:43 GMT 1
In theory (or by BS claim ) As My 1UA billet valves from the Aus Shyster did not fit /match the ports. Top or bottom of the ex port.. Grrr. Spent an hour apiece on them with a Burr making them fit
antos
Post by antos on Dec 18, 2017 16:13:49 GMT 1
I know when I bought my billet ones from Martin at mbd I had to specify 1 ua as he said there is a difference. My god thatโs reminding me how much I spent on it ๐
antos
Post by antos on Dec 18, 2017 16:15:31 GMT 1
All power valves same throughout the range only aftermarket billet valves address this , 1ua have higher ports 1mm from old memories n slightly wider , Yamaha originally done this to keep power output similar even though other changes didn't allow higher peak hp due to emissions police being on there case !!!. for those interested I can post up pics showing the difference between new 1ua barrels with standard valve n the other one with billet valve... id be interested if you could mate๐
Post by jessy03 on Dec 18, 2017 22:38:10 GMT 1
