Post by bryan on Aug 28, 2017 21:14:40 GMT 1
Completed the jobs on a 90% good loom with bits from a second one I had. Fuse box had 3 broken fuse holders, the blue was pulled out up to ignition switch connector. Loom Repair by Bryan Haynes, on Flickr The 2 live brown's were splice in about 6 inches up from fuse box. Loom Repair by Bryan Haynes, on Flickr Battery earth wire was cut off, so spliced in a new bit. Loom Repair by Bryan Haynes, on Flickr Headlamp bulb wires. Loom Repair by Bryan Haynes, on Flickr The replaced headlamp connector. Loom Repair by Bryan Haynes, on Flickr Ready for soldering joints and warming up heat shrink, then will be wrapped back up with the correct non adheasive loom tape. Loom Repair by Bryan Haynes, on Flickr The total cost was about £4 for the rolls, 1 roll was loom tape and other was electrical tape.
Post by bryan on Aug 29, 2017 22:20:39 GMT 1
Post by Shytalk on Aug 31, 2017 16:19:38 GMT 1
Nicely done Bryan, and the copper wire is looking fine which is always a bonus.
Post by bryan on Sept 1, 2017 20:39:39 GMT 1
Yes, should solder ok.
