Post by barney on Aug 21, 2017 23:23:31 GMT 1
What's the difference between the carbs I have read that you can fit Pv (31k)carbs to a Lc with a little mod? Is there any benefit? Cheers
Post by jon on Aug 22, 2017 7:38:14 GMT 1
I have 31k carbs on my LC. They work really well, with none of the usual flat spot before the power band.
Little difference in reality, just progression from the LC carbs. Probably newer too so less worn.
Post by barney on Aug 23, 2017 21:30:06 GMT 1
I have 31k carbs on my LC. They work really well, with none of the usual flat spot before the power band. Little difference in reality, just progression from the LC carbs. Probably newer too so less worn. Jon Thanks jon I may look at getting a pair,did you have to mod anything on the carbs?
Post by stusco on Aug 23, 2017 22:24:47 GMT 1
You need to block the vacuum Spigot for the Pv fuel tank
Post by barney on Aug 23, 2017 22:55:47 GMT 1
You need to block the vacuum Spigot for the Pv fuel tank Thank you mate👍
Post by dusty350 on Aug 25, 2017 19:49:59 GMT 1
Hi Also, a lot of guys using 31k carbs on Lc's fit 25 pilots instead of he standard 22.5's. Jon will confirm as he was the one that told ne !! Dusty
Post by barney on Aug 26, 2017 8:48:58 GMT 1
Hi Also, a lot of guys using 31k carbs on Lc's fit 25 pilots instead of he standard 22.5's. Jon will confirm as he was the one that told ne !! Dusty Cheers dusty👍
