Post by Mr Kipling on Jul 26, 2017 17:40:06 GMT 1
Post by midlifecrisisrd on Jul 26, 2017 20:27:09 GMT 1
Very helpful
Looks like they are similar to R cases
Post by 4l04ever on Jul 26, 2017 22:00:03 GMT 1
I think the front part of where the base gasket would sit is like an F2 or later casing, not like a 31K. There is extra metal there, which matches to some of the big bore Banshee top ends better. Can you post a pic looking down at that area?.....found your pic :- 118
Post by 4l04ever on Jan 2, 2018 19:55:09 GMT 1
Can the pics in this thread be restored?
Post by Mr Kipling on Jan 3, 2018 1:02:31 GMT 1
I,m on it ...ypvs pics tomo..
Post by 4l04ever on Jan 3, 2018 8:20:38 GMT 1
Cheers :-)
Post by lrcarl on Jan 3, 2018 9:09:19 GMT 1
Read a thread on rz forum about this Was claimed banshee cases thicker and Will take trenching for +10 crank Ypvs cases max +7 crank Carl
Post by markhoopy on Jan 3, 2018 18:02:26 GMT 1
Read a thread on rz forum about this Was claimed banshee cases thicker and Will take trenching for +10 crank Ypvs cases max +7 crank Carl I've got a set of Banshee cases that have had the work done to take a +10mm crank and also have a set of YPVS cases with +7mm crank. The Banshee cases definitely have a far deeper section than the YPVS ones and I doubt there is enough thickness left on the YPVS cases to machine for the longer-throw crank.
Post by muttsnuts on Jan 3, 2018 18:11:11 GMT 1
yep, if you try and do 10mm on ypvs you will break through or weaken them to the point that they will fail under use
Post by Mr Kipling on Jan 3, 2018 22:11:56 GMT 1
I,ll get a gauge on them both when I get the time... just by visual eyeballing them I can see a difference when there side by side.. I remember trinity saying even some banshee cases needed epoxying after trenching for 10mm cranks...There again maybe they done it just too safe guard..
