Post by jollyr6 on Jul 19, 2017 12:48:14 GMT 1
hi guys rebuilt engine put one of those new carbs on her and she takes ages to start last time i ended up putting petrol down barrel boom straight up stopped her then tried starting again started straight away yipee so left it over night went to start it day after and shes being a cow to start again any suggestions ?/
neil
my 125
Post by neil on Jul 20, 2017 23:20:36 GMT 1
Sounds like the choke circuit isn't functioning correctly.
Post by jollyr6 on Jul 21, 2017 12:23:02 GMT 1
Sounds like the choke circuit isn't functioning correctly. its a brand new out the box carb
neil
my 125
Post by neil on Jul 22, 2017 11:51:27 GMT 1
I'd still strip it down and inspect.
Post by mattybeckett on Jul 24, 2017 20:51:31 GMT 1
Cows are less problematic lol. Sounds like choke problem as previously mentioned, try removing rubber between carb and air box, hold hand flat over back of carb to seal it while trying to start, if she fires up the problem is choke HTH
Post by jollyr6 on Jul 27, 2017 21:19:03 GMT 1
Cheers guys seem to think I did that n it started last time ffs new carb I'll strip down after mot on Saturday cheers
Post by jollyr6 on Jul 31, 2017 12:07:47 GMT 1
Cows are less problematic lol. Sounds like choke problem as previously mentioned, try removing rubber between carb and air box, hold hand flat over back of carb to seal it while trying to start, if she fires up the problem is choke HTH yep you were right covered carb n boom second kick need to strip choke n see wharts up
