Post by lcowner on Oct 12, 2008 8:43:47 GMT 1
what do i have to do to just premix petrol in tank as regards pump? can i just premix and leave pump resv. empty,or do i have to disconnect pump/resvisor? dunno how to do this? premix would suit me as i know for certain that its getting the right mix. and i wouldent mind bringing small bottles 2 stroke wit me wen filling up at pumps............
Post by twostroker on Oct 12, 2008 20:56:38 GMT 1
yep asaiden said,ive always pre-mixed my fuel in jery cans at home,i think 40:1 is 125ml to 5 litres of fuel but dont quote me on that,if your mixing it in the tank make sure you give it a nice shake up when you fill it up and just before you start it up in the mornings as siome 2 stroke oil settles to the bottom of the tank over time
Post by vin on Oct 12, 2008 21:04:20 GMT 1
As far as blocking the feeds on the carbs, I just cut a 15mm piece of oil feed pipe and sealed one end with sealant. The rest as aiden said
russktm
Finally on the road!!
Post by russktm on Oct 13, 2008 20:29:08 GMT 1
I just used a length of oil feed pipe and joined the two carbs together.
russktm
Post by russktm on Oct 13, 2008 20:29:43 GMT 1
