Post by jorjasfather on Jun 1, 2017 22:44:43 GMT 1
Hi everyone last year i had a problem with a slipping clutch which i had purchased and installed it it was a EBC clutch kit with EBC heavy duty springs put new oil 10-30 in after that the clutch slipped like a beatch which I could not understand because it had been install correctly i did some research and checking oil was correct setting were right no problems with basket I was pulling my hair out so i bit the bullet and ordered a brand new clutch kitand springs which also was EBC install it all again put some more new oil and tried it a again and it was blob on i compared two or the springs even tho they were both EBC clutch kit and spring in seal boxes and bags for spring correct part numbers the spring were different i.e. the thickness of the spring coil were different I don't know if the first set were real EBC or fake
