Post by jorjasfather on May 25, 2017 18:35:44 GMT 1
Hi there everyone is the balancer shaft idle cog the same on all models and are the interchangeable
Post by wonkywheel on May 26, 2017 21:57:10 GMT 1
Hi there everyone is the balancer shaft idle cog the same on all models and are the interchangeable How strange, I can see why you are asking the question. Different part numbers, yet the balanec shaft and the pick up gear have same part numbers.
Post by jorjasfather on May 27, 2017 9:31:23 GMT 1
I ask in question because the r125lc 1GM has a riveted three peace gear which mine has a lot of play in it but the rd 125lc 10W has a one peace gear
Post by wonkywheel on May 28, 2017 8:53:31 GMT 1
I see. Does the rivetted one have some free-play to act as a damper? There are both types on ebay. As said- the balance shaft for all models has the same part number- so I would have thought that internal diameter, that fixes to the balance shaft, for the gears should be the same.
Post by jorjasfather on May 28, 2017 10:38:55 GMT 1
The rivets look like they are really warn so the gear is wobbleing and not due to being lose on the shaft
