Post by boost on Apr 28, 2017 15:48:39 GMT 1
hi all ive just bought a 1986 125 lc ypvs which I believe was imported from Switzerland ?? the engine and exhaust have 1GU stamped on them can anyone identify this code also is the bike full power and what does that equate to in bhp, ive only ridden the bike up a long drive way at the mo hence the power question cheers in advance
bob
Post by midlifecrisisrd on Apr 28, 2017 19:55:58 GMT 1
1gu should be an unrestricted 21hp bike
Post by boost on Apr 28, 2017 20:53:02 GMT 1
thanks for the reply midlifecrisisrd
bob
Post by museumman on Apr 28, 2017 22:06:21 GMT 1
how come the seller didn't know? The Swiss bike is listed on the docs as 15.5KW there are at least 4 extra features/restrictions in the exhaust to fight their noise problem but haven't had them on the dyno to see what is gained by removing each one, it wont be a lot. It's much heavier than the older exhaust(even without the end-can). If you look on the hanger it is stamped 1GX.
Post by boost on Apr 29, 2017 9:42:05 GMT 1
thanks for the reply museumman, do you have any info on the 1GU such as carb needle position and main jet size, as I bought the bike with a nikkon pipe on I also got the standard pipe with it which I have now fitted, and I'm wondering if the jetting or needle position may have been altered to suit the nikkon I asked the seller but he says he took it to a garage to be fitted and he is unsure what they did
cheers bob
Post by museumman on Apr 29, 2017 15:08:31 GMT 1
190 main 4th groove from top needle clip
Post by museumman on Apr 29, 2017 15:17:11 GMT 1
This is the main pipe looking back down it, there is normally a nozzle spot welded in there. I removed mine.
Post by boost on Apr 29, 2017 16:14:50 GMT 1
thanks museumman I appreciate the info, did you notice any difference when you removed the tube in the pipe
cheers bob
Post by museumman on May 1, 2017 17:55:38 GMT 1
It's a little bit louder and gains about 500 RPM top end with the baffle tube also adjusted (drilled or cut down) for better gas escape.
