Post by graeme6 on Mar 5, 2017 20:36:10 GMT 1
Considering skimming my flywheel bet don't know how much to take off. Anyone tried it and does it make any difference to performance or not worth the bother. Does anyone know the dimensions of the flywheel after skimming.
Post by graeme6 on Mar 6, 2017 10:26:35 GMT 1
Thanks, seen that Norbo has them but was going to skim my own if I can get some measurements, don,t want to take too much off!
Post by jollyr6 on Mar 6, 2017 13:39:47 GMT 1
Thanks, seen that Norbo has them but was going to skim my own if I can get some measurements, don,t want to take too much off! Let me know if you get the measurments will do mine hope norbo dosent mind sure he wouldn't if its only your own your doing
Post by jorjasfather on Mar 8, 2017 17:57:40 GMT 1
Hi there what engine code is it
Post by graeme6 on Mar 8, 2017 18:49:55 GMT 1
Flywheel stamped 1gm
Post by jollyr6 on Mar 8, 2017 23:42:35 GMT 1
Mines a 10w
Post by cinder on Mar 16, 2017 19:14:40 GMT 1
I always run a lightened flywheel on my 2t's.I think 3mm off the outside and men off the front face would be conservative.make sure you scribe your timing mark fully and radius all corners
r1yank
Post by r1yank on Mar 31, 2017 8:17:58 GMT 1
Will definitely be getting one of these from Norbo soon. Just for the extra throttle response it will be worth every penny.
Post by mattybeckett on Mar 31, 2017 22:35:40 GMT 1
Standard flywheels are balanced to perfection for a reason !!! Will give slightly quicker acceleration ' but cause more damage in the long run, unless balanced yet again. Bit like driving a car with a front wheel out of balance, shakes the car like mad, you will be doing the same to your crank etc
Post by jorjasfather on Apr 2, 2017 18:24:11 GMT 1
I have a 1GM motor in mine with a lighted flywheel and it measures 114mm diameter and 44mm from front face to back edge
Post by graeme6 on Apr 2, 2017 18:34:45 GMT 1
Does it feel as if the engine vibrates any more than a standard flywheel?
Post by jorjasfather on Apr 2, 2017 18:39:17 GMT 1
No it's fine and a lot lighter than standard
Post by Bertie Wooster on Apr 3, 2017 12:50:17 GMT 1
Mine is one of Norbo's flywheels got banshee coils on as well can feel difference
