Post by 350guy on Feb 5, 2017 2:25:09 GMT 1
Ladies/Gents: Please see attached pictures. I am sending my carbs for ultrasonic cleaning, I have removed most of the parts however the emulsion tube seems to be stuck. I tried tapping it from the other side where the throttle needle slides in. Am I forgetting something here, how do you guys get this out? Thanks in advance. Meilleures salutations, Daryl
Post by steeley on Feb 5, 2017 7:12:46 GMT 1
Hi, find a bolt to wind into the thread then tap the bolt .the tube goes towards the slide to remove. they are some times full of crud on the out side surface also check the small holes /drillings in it.
Post by midlifecrisisrd on Feb 5, 2017 11:47:44 GMT 1
I just use the jet
Screw it back in without the washer then tap on the bench and it should move up into the slide area
Post by dusty350 on Feb 5, 2017 15:50:17 GMT 1
Hi I use an old jet too. Screw an old jet back into place without the washer, and then I use a "G" clamp - 1 end (adjuster part) on the jet, the other over the top of the carb where the top screws on, then gently tighten the clamp. It pushes the tube out rather than knocking it out. If it's tight you can leave it under tension for a bit which may help start to shift it. If it moves but resists all the way, you may have to wind the jet out a bit to add a bit more length to exert pressure on. It can only be removed from the bottom upwards, and on reassembly the groove down the side corresponds with a pip in the carb body so be sure to line it up when popping it back in. Dusty
Post by 350guy on Feb 5, 2017 23:12:32 GMT 1
Gentlemen: Thank you so very much, I managed to get them off. Unbelievable gunk n junk in it! One of them were stuck and just wouldn't budge, I tried Dusty's trick et voila! Many thanks!
Cheers,
Daryl
Post by paulperth on Feb 6, 2017 13:06:39 GMT 1
Rather than sending them away for ultrasound send them to muttsnuts for a refurb they sound gunked up and he can machine the brass balls out and give it a proper clean at a very reasonable price -sorted mine out when I was back in pommy land at Christmas and the difference is outstanding
Paul
Post by Tobyjugs on Feb 6, 2017 17:52:16 GMT 1
Rather than sending them away for ultrasound send them to muttsnuts for a refurb they sound gunked up and he can machine the brass balls out and give it a proper clean at a very reasonable price -sorted mine out when I was back in pommy land at Christmas and the difference is outstanding Paul I agree with Paul but aren't you in Canada? It might be cheaper to fit some other good carbs rather than pay for the carriage and service unless you find someone local or do it yourself. I have seen a thread on here where someone posted how he did it.
Post by 350guy on Feb 6, 2017 18:21:54 GMT 1
Yeah, the carbs are a mess and the allu is all eaten up. I am in Canada. Where is pommy land??
Post by dusty350 on Feb 6, 2017 18:25:20 GMT 1
England ! It's what the Aussies call the English - poms or pommies !! Dusty
Post by 350guy on Feb 12, 2017 0:41:56 GMT 1
Sounds cool, good to know Dusty. Pommies rock!
Post by alankelly on Apr 26, 2023 21:39:44 GMT 1
Hi I use an old jet too. Screw an old jet back into place without the washer, and then I use a "G" clamp - 1 end (adjuster part) on the jet, the other over the top of the carb where the top screws on, then gently tighten the clamp. It pushes the tube out rather than knocking it out. If it's tight you can leave it under tension for a bit which may help start to shift it. If it moves but resists all the way, you may have to wind the jet out a bit to add a bit more length to exert pressure on. It can only be removed from the bottom upwards, and on reassembly the groove down the side corresponds with a pip in the carb body so be sure to line it up when popping it back in. Dusty Hi Dusty Great trick Cleaning some A/C carbs on behalf of a friend and emulsion tube well and truly stuck but a dip in a hot ultrasonic bath and using your clamp trick got them out Thanks again Al
Post by dusty350 on Apr 26, 2023 21:45:02 GMT 1
Glad that worked Al I never feel happy getting too "medieval" with delicate carb parts !! The G clamp shouldn't damage anything if care is taken
Post by chrisg on Apr 26, 2023 21:54:48 GMT 1
Gentlemen: Thank you so very much, I managed to get them off. Unbelievable gunk n junk in it! One of them were stuck and just wouldn't budge, I tried Dusty's trick et voila! Many thanks! Cheers, Daryl I remember taking a tube out in the past and it was full of crud but unbelieveably the bike ran ok.
Post by alankelly on Apr 26, 2023 21:56:17 GMT 1
Gentlemen: Thank you so very much, I managed to get them off. Unbelievable gunk n junk in it! One of them were stuck and just wouldn't budge, I tried Dusty's trick et voila! Many thanks! Cheers, Daryl I remember taking a tube out in the past and it was full of crud but unbelieveably the bike ran ok. Yes this is what it looked like Will be interesting what horrors lie hidden behind the brass ball
Post by JonW on Apr 27, 2023 6:18:54 GMT 1
yuk!
Post by veg on Apr 27, 2023 8:05:12 GMT 1
Just goes to show how well made the bikes are when they still run however roughly when in this state. The designers obviously understood the average teenage owners.
Post by JonW on Apr 27, 2023 8:19:43 GMT 1
Just goes to show how well made the bikes are when they still run however roughly when in this state. The designers obviously understood the average teenage owners. I totally agree with that comment, the poor workmanship and cheap/used parts we threw at our bikes in the early years would be essentially a nightmare for something modern, but back then they knew what to expect i guess.
Post by muttsnuts on Apr 27, 2023 13:44:28 GMT 1
what you mean back then, from what I see on a regular basis, its still going on, cheap crap and bodges being done on the bikes
Post by JonW on Apr 27, 2023 14:12:14 GMT 1
Ahh, must not be forumers youre getting as customers Dave!
