Post by spooch63 on Jan 13, 2017 23:00:42 GMT 1
Where ca I get an angel eye headlight from for a 350lc, be great if it fit into the headlight bowl without too much hassle, with a side light fitting would be handy.
Cheers
Post by Yogi on Jan 13, 2017 23:11:01 GMT 1
Hi mate Look for Anglia headlight on eBay they are £37 for a pair Take your bezel off and it fits straight in The halo is the side light,all the wiring fits with no mods Mines iridium but you get the idea Matt
Post by spooch63 on Jan 13, 2017 23:31:32 GMT 1
Cheers Yogi, will sort it out over the weekend, any mods for the iridium bulb?
Post by looey on Jan 13, 2017 23:35:17 GMT 1
Post by Yogi on Jan 13, 2017 23:36:31 GMT 1
Cheers Yogi, will sort it out over the weekend, any mods for the iridium bulb? No mate just buy iridium lights instead of clear Look at mini ,Anglia or Any fords they should come up Matt
Post by Yogi on Jan 13, 2017 23:39:51 GMT 1
Post by scootjockey on Jan 13, 2017 23:55:03 GMT 1
Don't suppose they do a square style for an F2 do they ?
Post by Yogi on Jan 14, 2017 0:06:29 GMT 1
Don't suppose they do a square style for an F2 do they ? I can't find one
Post by scootjockey on Jan 14, 2017 0:15:12 GMT 1
Don't suppose they do a square style for an F2 do they ? I can't find one I suppose gaffer tape and 4 small led strip lights won't get through an mot either !
Post by Yogi on Jan 14, 2017 0:24:46 GMT 1
I can't find one I suppose gaffer tape and 4 small led strip lights won't get through an mot either ! Get the mot and tape em on after
Post by icarus001 on Jan 14, 2017 6:30:04 GMT 1
They look brill, I've just bought some. I'll have a pair, one will go into my LC and I'm hoping the other fits into my N1?
Post by fozzy17 on Jan 14, 2017 7:33:55 GMT 1
Post by icarus001 on Jan 14, 2017 9:44:33 GMT 1
Yep, that's what I bought. Hoping they fit my N1 as well as my LC, I don't know if there are any differences between the headlights on the two.
Post by Yogi on Jan 14, 2017 9:46:45 GMT 1
They look brill, I've just bought some. I'll have a pair, one will go into my LC and I'm hoping the other fits into my N1? It should fit the n1 as well
Post by Denzil on Jan 14, 2017 10:19:10 GMT 1
Will they fit the N2 round head light. I am Guessing Mr Yamaha would have made all the round bowls the same size. Saying that I could just measure my one!!
Post by Shytalk on Jan 14, 2017 10:25:44 GMT 1
Will they fit the N2 round head light. I am Guessing Mr Yamaha would have made all the round bowls the same size. Saying that I could just measure my one!! Hi Denzil, yes if these fit the N1 they'll fit the N2 as the light is the same fitting.
Post by Denzil on Jan 14, 2017 10:32:54 GMT 1
Cheers big man.
Hope you are well mate. It's been like years since I last saw you.
Rd is having a refresh. Colour, cables , lights etc.
Post by midlifecrisisrd on Jan 14, 2017 11:59:12 GMT 1
They look brill, I've just bought some. I'll have a pair, one will go into my LC and I'm hoping the other fits into my N1? Problem with fitting them in a ypvs is that the original headlight has brackets on the rear that the adjuster bolts/springs connect to unlike the lc I have had a pair in the garage for a couple of years and never got round to trying to fit to a ypvs The only way I can see it working group is by taking an old euro ypvs so headlight and cutting it up so you are left with the front half of the bowl that has the brackets and bonding it onto the angle eye The lc and ypvs share the same glass so are the same diameter Steve
Post by wangwang on Jan 14, 2017 12:52:21 GMT 1
Post by icarus001 on Jan 14, 2017 12:53:03 GMT 1
They look brill, I've just bought some. I'll have a pair, one will go into my LC and I'm hoping the other fits into my N1? Problem with fitting them in a ypvs is that the original headlight has brackets on the rear that the adjuster bolts/springs connect to unlike the lc I have had a pair in the garage for a couple of years and never got round to trying to fit to a ypvs The only way I can see it working group is by taking an old euro ypvs so headlight and cutting it up so you are left with the front half of the bowl that has the brackets and bonding it onto the angle eye The lc and ypvs share the same glass so are the same diameter Steve I only really wanted it for my LC, it's tastefully modified so at first glance it looks standard(ish), and I thought it will look good, getting a pair was a bonus so I thought I'd try the other one on the N1. I don't have a lot of experience with YPVS's, so I'll have a look and if it won't work then I'm not too bothered. I am an absolute expert at bodging things making things fit, so I've no doubt I can cobble something up that will allow me to fit it to the N1 if I wanted I'm an Engineer by trade and make MacGyver look like an amateur
Post by spooch63 on Jan 14, 2017 20:22:32 GMT 1
Order placed, cheers Yogi !!
Post by icarus001 on Jan 15, 2017 11:27:02 GMT 1
I think there is a trend being set here
Post by petehodges on Jan 15, 2017 12:18:11 GMT 1
yer now i,m bloody looking aswell its all yogis fault hes got a lot too answer too
Post by russpuss on Jan 15, 2017 12:30:02 GMT 1
Just ordered too!
Post by gci_scot on Jan 15, 2017 12:45:24 GMT 1
I am ordering too !!
Post by reggieperrin on Jan 15, 2017 13:04:42 GMT 1
I have a spare one on the shelf as I bought a pair for the YPVS that i was restoring.. They don't fit the YPVS easily, quite a bit of faffing about....
As said though, drops straight into a LC
Post by rich on Jan 15, 2017 15:47:37 GMT 1
I also have the angle eye headlight in my LC. Works well, only criticicsm is the lens has gone slightly cloudy since I bought it about 2 years ago.
Post by petehodges on Jan 15, 2017 18:16:37 GMT 1
Rich is that a clear lens ?
Post by rich on Jan 15, 2017 18:23:16 GMT 1
Rich is that a clear lens ? Yes
Post by mouse on Jan 15, 2017 20:18:29 GMT 1
Sorry if this is a daft question, but
As these are car headlights does the beam point to the left or is straight ahead like a motorbike?
Cheers Mouse
