Post by twostroker on Aug 18, 2008 20:52:29 GMT 1
has any body tryed fitting a bigger reed block?350 ypvs or kr1s block might work well? im thinking of fittind a v-force one and wondered if any one else has done it before i spend more cash
Post by typer196 on Aug 18, 2008 21:39:13 GMT 1
Yes, i have recently fitted one to my MK3. You have to open the inlet right up using a dremel or die grinder on both sides, top and bottom + fit 2 reed spacers , it's a daunting job, however well worth it once completed. I have yet to get my barrel back as Norbo is reboring it, however ad (rd125lc85) has fitted one to his and it gives a good power gain.
Post by twostroker on Aug 20, 2008 6:53:14 GMT 1
Yes, i have recently fitted one to my MK3. You have to open the inlet right up using a dremel or die grinder on both sides, top and bottom + fit 2 reed spacers , it's a daunting job, however well worth it once completed. I have yet to get my barrel back as Norbo is reboring it, however ad (rd125lc85) has fitted one to his and it gives a good power gain. ive allready got one reed spacer and my ram air filter is almost touching the rear shock,what carb and filter is he using? im usung a kr1s pwk28 carb and ram air filter, is rd125lc85 the guy who had the big bore liner conversion done? im just worried that i mite grind my barrel out and run into problems
Post by typer196 on Aug 21, 2008 20:52:21 GMT 1
Yeah you do very almost touch the monoshock! However ad (rd125lc85) is using the 26mm derestricted mk2 rd carb with k&n and filter spacer and it does come mighty close to the shock however does not restrict it's operation. Ad hasn't had the big bore conversion, he's on around his 5th oversize i think. When grinding out the barrel inlet, its not actually the ports a such your touching, it's the area either side the reedvalve sit's in, you have to take out around 2mm either side otherwise the v force won't sit in as its to narrow as standard + take meat out of the top and bottom (bottom mainly) so the reed's can open to their best potential. It is a gruelling job and you do come close to going through the side if your not careful, however all the effort does pay off!
Post by racerd on Aug 26, 2008 23:51:22 GMT 1
Post by racerd on Aug 26, 2008 23:53:34 GMT 1
could you leave out the reed block spacer and use a spacer tube on the back of the carb also you could reprofile the back of reed stops to get even more lift
Post by typer196 on Sept 15, 2008 0:28:01 GMT 1
No, it's essensial you fit the two reed spacers otherwise you wont be able to fit the V-force into the barrel, as the the barrel tapers in towards the ports.
Post by Dirtbag on Sept 22, 2008 8:32:22 GMT 1
If you're a bit handy with the old Dremel , these diagrams might come in handy...............Piston tuning and reed-block tuning
Post by racerd on Sept 22, 2008 13:28:26 GMT 1
i have photos for reed block tuning and piston tuning on my web site
Post by twostroker on Sept 22, 2008 19:46:47 GMT 1
If you're a bit handy with the old Dremel , these diagrams might come in handy...............Piston tuning and reed-block tuning your pics arnt working,any chance you can re-do them as they will be realy helpull to me
Post by Dirtbag on Sept 23, 2008 9:08:55 GMT 1
They should be working ok they are on my PC...........uploaded to photobucket alright too
Post by twostroker on Sept 23, 2008 19:41:35 GMT 1
sorry it must be my pre-war computer not wanting to display pictures again,never mind.
Post by Dirtbag on Oct 2, 2008 9:14:33 GMT 1
Pics should be working ok now
