Post by shunter on Nov 2, 2016 11:30:46 GMT 1
I probably should have done this before now but I have just checked the fuse box on the lc and found fuses of all amperage but none are correct,i now have the correct ones 1x20 3x10 can someone please tell me which order they go in from left to right. Many thanks.
Post by markhoopy on Nov 2, 2016 11:38:34 GMT 1
Best pic I have ..
Post by looey on Nov 2, 2016 12:11:56 GMT 1
The one red wire in there is usually main battery wire, so is the 20A fuse, the others are all 10A
If you're not sure (and you never know what stupid things people do over the years), just pull the fuses out one at a time to see what stops working.
The 20A fuse should kill everything.
One 10A fuse will stop the high and low beam headlight
One 10A fuse will stop the side lights
One 10A fuse does the indicators and idiot lights (I think)
Something like that anyway, worth spending 2 mins checking for yourself I reckon
Post by markhoopy on Nov 2, 2016 12:29:13 GMT 1
The pic I posted shows from left to right - with left being the end that the wires enter the fuse box - marked as 10 Amp Tail, 10 Amp Signal, 10 Amp Head and 20 Amp Main.
Post by shunter on Nov 2, 2016 23:59:26 GMT 1
Perfect thanks very much.
