Post by graeme6 on Oct 31, 2016 21:00:46 GMT 1
Can anyone tell me if this is a standard Mk2 125 LC caliper as when I bought the bike it was in bits and came with three different types of caliper. Need to know so I can order a set of pads. Thanks Graeme
Post by graeme6 on Oct 31, 2016 21:04:37 GMT 1
this is the other calipers, both similar but one has two bleed nipples and the other only one. Also spring clip is different.
Post by wonkywheel on Oct 31, 2016 22:38:26 GMT 1
One bleed screw.
Post by graeme6 on Oct 31, 2016 23:09:09 GMT 1
What about the gold caliper, is that standard.? Do you have any photos of a standard caliper.
Post by wonkywheel on Oct 31, 2016 23:56:31 GMT 1
The gold could be off a mk3, or a F2 ypvs. The silver/grey could be off a 350r or a fzr Mk2 and mk3 are the same and have one bleed screw In the past I fitted a right handed F2 calliper. I would say they are the same calliper because i have fiitted F2 pistons, seal kit and pads to a mk2 body calliper- perfect fit. If I am in the garage at the weekend- i'll post some pics
Post by graeme6 on Nov 1, 2016 20:58:33 GMT 1
thanks a lot, much obliged.
Post by Mr Kipling on Nov 2, 2016 23:25:47 GMT 1
Hi Graeme looks to me like the same caliper as fitted to the mk3 rd / tzr125 mk 1, measure the i.d bore size of the piston mk1 tzr 38.1mm later mk2 tzr 42.8mm
Post by graeme6 on Nov 3, 2016 8:15:12 GMT 1
thanks, will check it out next time I can get in the shed.
