Post by midlifecrisisrd on Oct 23, 2016 14:01:14 GMT 1
Seen this queried before and thought I'd give it a bash as I'd done the shrouds before Knew the clear lens was boned into the molding so thought i'd try this way cut a good lens out a knackered cover around the lip which is double skinned Cut cracked lens out Ground around lens Dremeled out cover to fit lens checked fit Bonded on rear All done, just needs cleaned and some black gloss rubbed in the join. Need to fit an ignition surround to it now Steve
Post by stusco on Oct 23, 2016 14:31:38 GMT 1
Good skills
Post by LC_BOTT on Oct 23, 2016 14:50:50 GMT 1
that looks just like from the factory, is there no way you can just replace the clear lens?
Post by midlifecrisisrd on Oct 23, 2016 15:01:00 GMT 1
that looks just like from the factory, is there no way you can just replace the clear lens? Not without it looking different It looks like the lenses are placed in the mold then the black injected around them. The result is they have the black casting bonded above,below and all around so no way to get to the edges of the lens to replace it and have a 100% water proof joint Steve
Post by Yogi on Oct 23, 2016 18:49:17 GMT 1
Nice one Steve Looks like you've found a decent way to save some of these kidney clocks Matt
Post by midlifecrisisrd on Oct 23, 2016 18:58:07 GMT 1
Nice one Steve Looks like you've found a decent way to save some of these kidney clocks Matt Cheers Matt Need to find a supply of them lol Steve
Post by Yogi on Oct 23, 2016 19:07:49 GMT 1
Nice one Steve Looks like you've found a decent way to save some of these kidney clocks Matt Cheers Matt Need to find a supply of them lol Steve I'll see what I've got,lol Matt
Post by mattybeckett on Oct 23, 2016 20:39:09 GMT 1
Great job done there, also that Qbond is a lifesaver at times
