Post by hardhatharry on Aug 6, 2016 17:00:54 GMT 1
Slowly building this RD400D engine up but a bit stuck again. The little plastic gear off the rev spline I seem to have 3 different ones to choose from a small one with 2R9 stamped into it, a medium sized one which has 2BO stamped into it and a large thick one with 1A0 stamped into it, which one should I use? Also the large gear of the gearbox looks wrong not like the one in the Haynes Manual and doesnt have a gear underneath it to connect to the kickstart Should it be this one?
Post by arrow on Aug 6, 2016 19:16:38 GMT 1
Not too sure, but its not the 1AO gear. That one is for the oil pump worm.
Post by hardhatharry on Aug 6, 2016 19:44:32 GMT 1
discontinued too, I see trouble ahead
Post by arrow on Aug 6, 2016 20:05:44 GMT 1
discontinued too, I see trouble ahead What is?
Post by hardhatharry on Aug 6, 2016 20:43:42 GMT 1
the tacho gear
Post by arrow on Aug 7, 2016 1:33:35 GMT 1
Ok. You have a choice there, and only on will fit correctly with the other gears??
Post by hardhatharry on Aug 7, 2016 10:23:52 GMT 1
Yes but none are the 1A0 21 tooth one unfortunatley
Post by arrow on Aug 7, 2016 12:08:51 GMT 1
1AO 21 tooth is the wormshaft gear.
Post by hardhatharry on Aug 7, 2016 12:14:34 GMT 1
Managed to get one from the US along with the other gear that looks wrong too.
