Post by jorjasfather on Jul 24, 2016 10:08:44 GMT 1
Hi there I have a issue with the clutch on my rd125lc mk2 1gm I got my hands on a brand new clutch basket I also replaced the clutch plates and slipper plates springs all are ebc and used new 10/30 wet clutch gear box oil i have set the clutch arm up with cast arrow on the case but the clutch still slips even with the push rod backed right off it still slips do you thinks it could be the spring even tho they are brand new uprated ones any advise would happy
Post by dan4771 on Jul 29, 2016 15:19:06 GMT 1
prob wrong but make sure basket is the same, as a bit of play there will cause clutch slip. i have experienced it with a dt basket in a rd engine.
Post by jorjasfather on Aug 3, 2016 19:11:10 GMT 1
Hi there it's the same part number as the orginal one and it looks the same
