Post by carlos on Jul 20, 2008 17:36:24 GMT 1
I got my engine back from Taymar today, and apart from fingermarks on my shiny alloy, all seems to be well, although, I wont know for sure until it's running!
130 quid plus parts for a full rebuild, including crank, and every bearing!
I'll tell you when it's all running, hopefully wednesday night!
Post by carlos on Jul 21, 2008 20:49:39 GMT 1
It sparks!
A bit of wiring to sort though! I had a 3 pin connector one end of the wiring, and 3 bullet connectors the other end!
Post by stevebozzy on Jul 21, 2008 22:50:36 GMT 1
hi, have you had it tuned ?
Post by carlos on Jul 22, 2008 18:23:15 GMT 1
No, it's bored out to +1.5mm, and the exhaust port is polished!
It's bored to the piston though, rather than just to 1.5mm over size! So any tollerances in the manufacturing process of the piston (ie, it may actually be 1.48mm) are eliminated, therefore, it should have loads of compression!
Post by carlos on Jul 28, 2008 21:02:03 GMT 1
She's in and running! Once I get the exhaust I'll set the carb up, she takes a bit of starting!
