kevb
Post by kevb on Jul 12, 2016 12:42:54 GMT 1
Hello I have an issue with the tap on my RD400 dripping when turned off, this is obviously causing the carbs cylinders crankcase etc to fill with petrol if left even overnight not good. I have tried a new tap seal kit, another tap not aftermarket taps which was supposed to be a good one. I need to try either a nos tap, which again will be old and may also drip, or any other alternative available. I have blanked one outlet off, and am using a y piece to feed both taps at the moment. Besides turning the tap off I also clamp the pipe as a short term measure when not in use. Has anyone had this issue, I dont want to waste money on yet another dripping tap. Any suggestions welcome.
Kev
Post by johna on Jul 12, 2016 22:05:02 GMT 1
tour max taps are good quality japanese made taps more or less oe you can get them off ebay.
Post by Norbo on Jul 13, 2016 7:00:18 GMT 1
you could try a TZ tap jap made but they only have 1 out let so would need a T pice but i have found that most after marlket twin out let ones are not that good but the jap made TZ ones are excelent .
