kevb
Post by kevb on Jul 9, 2016 11:18:14 GMT 1
Hello Further to my possible carb issues. It was suggested that I try some better needles 5LI, stockist (Allens performance Nottingham) I stripped my carbs, the needles that are in my carbs at present are marked 5L3, manual says 5L1-3 are correct. I spoke with a very helpful chap called Dave at Allens who told me the suffix 3 is the default groove setting recommended for clip. i.e. centre groove to start from. Does any one recognize the number on my needles 5L3. I am sure they will be the right ones supplied in the aftermarket carb rebuild kit that was used, but may not be as accurate as the 5L1 needles suggested my a couple of you forum lads. I will order a pair from Allens and try them. Anyone recognize 5L3 needles? and if they are suspect or not.
Kev
Post by oldelsieboy on Jul 9, 2016 16:00:24 GMT 1
5L3 needles were fitted to the 250D carbs You may also want to check which emulsion tubes are fitted. OEB
