samlig
Reeds
May 17, 2016 22:00:20 GMT 1
via mobile
Post by samlig on May 17, 2016 22:00:20 GMT 1
Just put some hytech fibre reeds in over the original ones, just wondering if they should sit about 0.5mm off of the reed cage? The original ones were say on it flush
Reeds
May 17, 2016 23:41:56 GMT 1
Post by wonkywheel on May 17, 2016 23:41:56 GMT 1
My hytechs sit the same.
Reeds
May 18, 2016 7:26:57 GMT 1
Post by Norbo on May 18, 2016 7:26:57 GMT 1
were they new reeds you fitted
samlig
Reeds
May 18, 2016 18:57:15 GMT 1
via mobile
Post by samlig on May 18, 2016 18:57:15 GMT 1
Yeah, swapped them out for the standard ones.
samlig
Reeds
May 18, 2016 18:57:44 GMT 1
via mobile
Post by samlig on May 18, 2016 18:57:44 GMT 1
How does yours run with them compares? I haven't got round to sorting mine out completely yet
Reeds
May 18, 2016 19:45:34 GMT 1
Post by wonkywheel on May 18, 2016 19:45:34 GMT 1
How does yours run with them compares? I haven't got round to sorting mine out completely yet I can't really give you any worthwhile feedback at the moment. I have just rebuilt my engine- yet I have running issues. I know the engine has been built well and the carb is sound. New coil on order as the spark looks poor, fouled plug and ohms test confirms. What's yours running like? I did notice the same clearance.
samlig
Reeds
May 18, 2016 22:46:01 GMT 1
via mobile
Post by samlig on May 18, 2016 22:46:01 GMT 1
How does yours run with them compares? I haven't got round to sorting mine out completely yet I can't really give you any worthwhile feedback at the moment. I have just rebuilt my engine- yet I have running issues. I know the engine has been built well and the carb is sound. New coil on order as the spark looks poor, fouled plug and ohms test confirms. What's yours running like? I did notice the same clearance. Just been faffing with it tonight, seems to be running a bit poor. I need to fill up fuel wise as it runs like a bag of ' when it's empty. I'll give you an update when I'm sorted with it. I had some bad carb troubles when I first got mine though
Reeds
May 19, 2016 10:09:36 GMT 1
Post by Norbo on May 19, 2016 10:09:36 GMT 1
new ones should fit flat try turning them around
Reeds
May 19, 2016 19:09:12 GMT 1
Post by wonkywheel on May 19, 2016 19:09:12 GMT 1
I can't really give you any worthwhile feedback at the moment. I have just rebuilt my engine- yet I have running issues. I know the engine has been built well and the carb is sound. New coil on order as the spark looks poor, fouled plug and ohms test confirms. What's yours running like? I did notice the same clearance. Just been faffing with it tonight, seems to be running a bit poor. I need to fill up fuel wise as it runs like a bag of ' when it's empty. I'll give you an update when I'm sorted with it. I had some bad carb troubles when I first got mine though Just fitted a new coil this evening and its now running much better- it revs out. This is interesting... I took out the read block and turned the reeds over and there is still a small gap. It still ain't perfect, ticker over is up and down and occasionally it hesitates and boggs down when you open the throttle. What are your symptoms?
samlig
Reeds
May 20, 2016 16:54:38 GMT 1
via mobile
Post by samlig on May 20, 2016 16:54:38 GMT 1
Won't loose revs right, ticking over at 3k up wards. Had this before with the empty tank thohhh
Reeds
May 20, 2016 20:21:22 GMT 1
Post by wonkywheel on May 20, 2016 20:21:22 GMT 1
Won't loose revs right, ticking over at 3k up wards. Had this before with the empty tank thohhh Same here... one minute its ticking over, next its up to about 3k, rev it up it goes down, then up... no consistency. I had a set of HiTecs back in the day and never had a problem. Are yours new- where did you get them from? I got my from... Yambits who claim they are the real deal.
samlig
Reeds
May 24, 2016 0:13:09 GMT 1
via mobile
Post by samlig on May 24, 2016 0:13:09 GMT 1
I got mine from hytech ebay shop, the gap shouldn't make a difference in theory as of the negative pressure created. Did you have a gasket inbetween the reed cage and the cylinder?
Reeds
May 24, 2016 20:38:59 GMT 1
Post by wonkywheel on May 24, 2016 20:38:59 GMT 1
I got mine from hytech ebay shop, the gap shouldn't make a difference in theory as of the negative pressure created. Did you have a gasket inbetween the reed cage and the cylinder? Yes- gasket fitted.
Reeds
May 24, 2016 21:35:22 GMT 1
Post by steve h on May 24, 2016 21:35:22 GMT 1
The little gaps are no prob. The reeds are opened and closed by crankcase pressure. Back in the day the best racing reeds were "Harpower" reeds. every so often you had to take them out of the blocks and using hot water, bend them into a bow shape, with a 1.5mm gap between the reed and the middle of the cage, with the tips of the reed touching the cage. The reeds were manufactured from Irish linen and some sort of resin.
begbie
Reeds
May 24, 2016 22:03:44 GMT 1
Post by begbie on May 24, 2016 22:03:44 GMT 1
I got mine from hytech ebay shop, the gap shouldn't make a difference in theory as of the negative pressure created. Did you have a gasket inbetween the reed cage and the cylinder? Sounds like you have an air leak somewhere between the carb and barrel. let it tick over then to confirm spray some carb/brake cleaner around all mating surfaces.
samlig
Reeds
May 26, 2016 9:42:35 GMT 1
via mobile
Post by samlig on May 26, 2016 9:42:35 GMT 1
I got mine from hytech ebay shop, the gap shouldn't make a difference in theory as of the negative pressure created. Did you have a gasket inbetween the reed cage and the cylinder? Sounds like you have an air leak somewhere between the carb and barrel. let it tick over then to confirm spray some carb/brake cleaner around all mating surfaces. I thought this, sprayed some carb cleaner and it didn't start to rev erratically or anything which I was surprised at.
samlig
Reeds
May 26, 2016 9:43:05 GMT 1
via mobile
Post by samlig on May 26, 2016 9:43:05 GMT 1
I got mine from hytech ebay shop, the gap shouldn't make a difference in theory as of the negative pressure created. Did you have a gasket inbetween the reed cage and the cylinder? Yes- gasket fitted. Where did you get it from or did you just tap it out of gasket paper?
Reeds
May 26, 2016 21:34:49 GMT 1
Post by wonkywheel on May 26, 2016 21:34:49 GMT 1
I got mine in a kit. Seems ok to me. Tried the spray test- no leaks. Started like a bag of shite this evening. After bogging down, no pick up, then back- firing it started to behave its self. It aint right- just wish I had a set of steel reeds to compare. Its a total head fu*k and embarrassing.
Reeds
May 27, 2016 20:36:58 GMT 1
via mobile
Post by jorjasfather on May 27, 2016 20:36:58 GMT 1
Is the woodruff key ok
