Post by Deleted on Jun 16, 2008 20:52:44 GMT 1
you should know better.........trial and error for each individual bike dear boy, try a high jet say 180 then come down till the colour is right, ok ;D
Post by twostroker on Jun 16, 2008 21:49:30 GMT 1
you should know better.........trial and error for each individual bike dear boy, try a high jet say 180 then come down till the colour is right, ok ;D plug chops seem to get mentioned alot on this type of forums but ive never seen a defenent guide to which colour is ideal and what incorrect colours atcualy mean,could any one point me in the right direction as im going to be doing a few plug chops soon and any experienced advice would be appericeated.
Post by mellow on Jun 16, 2008 21:52:57 GMT 1
there are pictures in haynes manuals usually of correct running engines m8
Post by Norbo on Jun 17, 2008 17:16:17 GMT 1
Ideal is a bisket brown but sod that i go for black
Post by Deleted on Jun 18, 2008 14:34:41 GMT 1
Jamie did it as an experiment to see how the bike went...only a bez up road say 1/8th mile to see how it sounded...lot better tbh and knew i needed to up jet but only a short blast and couldn't see point mate..no harm done....well apart from it wheelies on the throttle...lol that's how you do a chop mate how else are you gonna work out the correct set up with out riding it? short sharp test runs are OK to get the perfect set up. as for colour i call it shit brown, (as mellow says colours in Haynes), mid (shit colour) brown with minimal deposits all over the plug, any other colours you should re-jet or reset (1/4 of a turn at a time) the air screw. hope this helps.........
Post by racerd on Aug 27, 2008 0:16:32 GMT 1
though plug chops were done wot in third gear and wot 4th gear and hold wot in 4th gear upto 2 minutes then pull clutch lever in and at the same time flick kill switch to off when you have done that plug chop to see the colour of the burn change jetting if needed then when thats right go wot in 5th gear and wot in 6th gear and hold it for a couple if minutes then pull clutch lever in and flick the kill switch to off then look at the burn of the spark plug ie under full beam on head lamp black is too rich
