Post by andrew12345 on Mar 5, 2016 22:14:51 GMT 1
hi all i got a set of forks on ebay and this is what it said A SET OF YAMAHA RD250LC / RD350LC 4LO LATE TYPE FORKS WITH DRAIN BOLTS IN GOOD USED CONDITION..THE LEGS HAVE A FEW MARKS BUT SHOULD POLISH OUT NO PROBLEM.. THE CHROME ON STANTIONS IS GOOD WITH JUST A FEW VERY TINY SPECS NOT IN TRAVEL AREA AND DON'T LEAK AND ALL THREADS ARE GOOD. ANY QUESTIONS PLEASE ASK i got them this week as i was working did not get the parcel opened to 2 days later when i opened the parcel took them out and there was oil on them lefted up dust boots and there was oil under them they need seals and oil put this to seller at the price of £21.50 and he said send them back ?
Post by LC_BOTT on Mar 5, 2016 22:22:09 GMT 1
Yes annoying, but only to be expected. If the stanchions are good, cheange them yourself, cheap, easy and will last years. If they are c##p send them back, how much did you pay??
Post by markhoopy on Mar 5, 2016 22:26:28 GMT 1
Open a dispute and use the option 'item not as described' The seller should then agree for them to be returned. Ebay will give you a postage label to print out so you can return the forks. The seller pays postage costs. Re-pack the forks and drop off at a post office. Item is tracked by ebay and the seller has seven days after receiving it to refund your payment in full. Do not send the forks back unless you go through these steps first. If you do you will end up paying postage costs yourself
Post by markhoopy on Mar 5, 2016 22:27:52 GMT 1
Just out of interest what is the username of the seller? Doesn't happen to be from Wales by any chance?
Post by looey on Mar 5, 2016 22:28:03 GMT 1
If that's the seller's attitude you only have 2 options........
Keep em and fix em, or send em back.
If you file a returns request as "item not described" then the seller usually has to pay the return postage. Maybe he's not aware of that ?.
Post by jon on Mar 6, 2016 8:23:09 GMT 1
Andrew this is a tricky one to call without seeing the forks.
Firstly I would weight up how much they cost (as LC_BOTT asks) + £20+ for the seals etc and see if that is a fair price.
At an estimate I would expect to pay £100 - £150 for a good set of unleaking second hand forks these days.
If they were cheaper than this and the chrome in the stantion travel areas looks good I'd be tempted to risk resealing them.
Worst case scenario is paying another £160+ to have them re-chromed. Welcome to the expensive joys of RD ownership.
