Post by cruiser on Dec 28, 2015 11:59:03 GMT 1
Hi guys has anyone changed crank seals on YDS 7 , I'm just doing top end take down and think I should do seals at same time, any advice would be apreciated, thanks in advance
Post by wonkywheel on Dec 28, 2015 20:59:53 GMT 1
I have no experience of working on this fine model. Hope the air cooled chaps can help you. Firstly check whether the seals can be changed without splitting the crankcases. Try to see if you can still buy genuine seals. If you can get part numbers, your local Yamaha dealer will advise you on availability. It might be worth fitting the top end and see how it runs before changing seals.
lance
Post by lance on Jan 2, 2016 11:05:45 GMT 1
Message brianh or shag they will know and help
Post by muttsnuts on Jan 2, 2016 13:08:17 GMT 1
engine out and crank cases need to be split, same set up as the C/D models, think the seals might actually be the same as well
HTH
Post by Norbo on Jan 3, 2016 10:11:15 GMT 1
they are the same seals as the A?B models and all models need to split the casing and you need to change both as they pinch so you cant fit old seals a second time even if 1 hasent gone it will if you re fit.
