ricky13
SPEED TRIPLE R RD350YPVS
Post by ricky13 on Dec 13, 2015 22:09:45 GMT 1
Guys Just went into the garage and fired up the RD fired up first time but petrol pouring from left carb, strange as the bike hasnt moved since last week what do you think Cheers Ricky
Post by stusco on Dec 13, 2015 22:17:29 GMT 1
Give the bowl a tap
ricky13
Post by ricky13 on Dec 13, 2015 22:19:54 GMT 1
will do float sticking do you think
Post by 137d on Dec 13, 2015 22:22:55 GMT 1
Post by davey on Dec 13, 2015 22:24:18 GMT 1
Scrap it ive had nothing but problems with my lc2 , pain in the ass , problem after problem so its just sitting in my garage now until i can muster up the inclination to investigate the next issue My 4l1 has apart from a miss fire has been spot on for 10000 kms , i actually use it more than my fz8 .
Post by 137d on Dec 13, 2015 22:28:07 GMT 1
Always good to have a few options
ricky13
Post by ricky13 on Dec 13, 2015 22:44:49 GMT 1
certainly a few options, i might not try the scrapping method just yet,
mikeb
Post by mikeb on Dec 20, 2015 0:48:20 GMT 1
Mine needs the float bowls tapping after it's been stood more than a few days. I put it down to the ethernol evaporating and leaving the float valves to dry out.
everything inside my carbs is new, and i never solved it.
just give each side a tap before turning the tap to prime then if no leaks go to "on"
modern fuel is not designed for carbs, it's for injection systems
bngt
Post by bngt on Dec 23, 2015 0:47:32 GMT 1
Seems to help using a separate bike stand to get it vertical.
Post by Tobyjugs on Dec 23, 2015 11:05:31 GMT 1
Mine needs the float bowls tapping after it's been stood more than a few days. I put it down to the ethernol evaporating and leaving the float valves to dry out. everything inside my carbs is new, and i never solved it. just give each side a tap before turning the tap to prime then if no leaks go to "on" modern fuel is not designed for carbs, it's for injection systems Hi mikeb are you using an oil pump or premix?
mikeb
Post by mikeb on Dec 24, 2015 2:34:40 GMT 1
I use the oil pump
Post by rigga on Dec 24, 2015 3:36:00 GMT 1
No ethenol in premium fuels, so use v power or BP ultimate.
mikeb
Post by mikeb on Dec 25, 2015 1:33:21 GMT 1
I always use premium fuel, makes no difference to my carbs they still stick
Post by peevee350 on Dec 29, 2015 21:11:32 GMT 1
Sticking float. Remove bowl clean and restore
mikeb
Post by mikeb on Jan 7, 2016 11:50:45 GMT 1
that's not the case!
new floats, new pins, new valves, ultrasonically cleaned carbs!
there is nothing left!
however, i have just found the cure. go into the garage everyday and turn the tap to prime, then back to on. Just never let the float bowls dry out, that's when they stick.
Post by steven on Jan 7, 2016 12:30:19 GMT 1
