Post by wonkywheel on Sept 26, 2015 18:00:30 GMT 1
“You must be mistaken Officer, there’s no way you clocked me at 85mph- this LC is restricted to 12bhp.”The snake is out...
Post by jorjasfather on Sept 26, 2015 18:31:01 GMT 1
I remember doing that myself lol
Post by mudguts on Sept 26, 2015 19:37:43 GMT 1
still kept my tube from when i was 17,
Post by crash on Sept 27, 2015 17:48:14 GMT 1
I got two of them
Post by museumman on Sept 30, 2015 19:19:55 GMT 1
It always makes me laugh when people call the restriction "A washer" my MTX 50 was a bast*rd as the expansion pipe had to be cut in two places to remove the "washer" and rewelded. The welder in our local garage was an absolute artist, the seams he made looked better than factory.
the smaller pipe should get a little bit more low down torque iirc. Is that a 12A pipe or 46W?
Post by wonkywheel on Sept 30, 2015 19:30:04 GMT 1
It always makes me laugh when people call the restriction "A washer" my MTX 50 was a bast*rd as the expansion pipe had to be cut in two places to remove the "washer" and rewelded. The welder in our local garage was an absolute artist, the seams he made looked better than factory. the smaller pipe should get a little bit more low down torque iirc. Is that a 12A pipe or 46W? I have't looked yet. I suspect its a 12a as it's a UK bike. Back in the day I had an Allspeed etc, yet I did switch every now and then back to the 12A (restrictor out) exhaust due to the ride ability- better bottom end and midrange without the flat spot. Whats the difference between the 12A and 46W- alloy can, baffles- down pipe diameter?
Post by museumman on Sept 30, 2015 19:59:56 GMT 1
It always makes me laugh when people call the restriction "A washer" my MTX 50 was a bast*rd as the expansion pipe had to be cut in two places to remove the "washer" and rewelded. The welder in our local garage was an absolute artist, the seams he made looked better than factory. the smaller pipe should get a little bit more low down torque iirc. Is that a 12A pipe or 46W? I have't looked yet. I suspect its a 12a as it's a UK bike. Back in the day I had an Allspeed etc, yet I did switch every now and then back to the 12A (restrictor out) exhaust due to the ride ability- better bottom end and midrange without the flat spot. Whats the difference between the 12A and 46W- alloy can, baffles- down pipe diameter? 46W is the the same as a 12A pipe (restricted with "washer" , removable baffles too) but found on imports, yours looks nice and clean so jumped to conclusion it was an import The 46W bike has 17HP with restricted pipe and came fitted with the 10W carb (although looking at your photo, the 46W may have a shorter restrictor pipe, I'll have to dig mine out, don't throw yours away)
Post by wonkywheel on Sept 30, 2015 20:18:09 GMT 1
I have't looked yet. I suspect its a 12a as it's a UK bike. Back in the day I had an Allspeed etc, yet I did switch every now and then back to the 12A (restrictor out) exhaust due to the ride ability- better bottom end and midrange without the flat spot. Whats the difference between the 12A and 46W- alloy can, baffles- down pipe diameter? 46W is the the same as a 12A pipe (restricted with "washer" , removable baffles too) but found on imports, yours looks nice and clean so jumped to conclusion it was an import The 46W bike has 17HP with restricted pipe and came fitted with the 10W carb (although looking at your photo, the 46W may have a shorter restrictor pipe, I'll have to dig mine out, don't throw yours away) There’s the restrictor. I’m lucky- as the cigar exhaust is in good nick with no dents and original paint. I suspect it was ripped off for an Allspeed Micron etc and has sat around for 30 years in the back of a dry garage.
