Post by wonkywheel on Sept 20, 2015 19:27:55 GMT 1
Hi, Need a bit of advise for a Mk2 inner tube for the front wheel. Can't find a 80/100/16 tube. This is what I have found: 250/275/16 275/300/16 Would either be ok? I'll probably be fitting the standard 80/100/16 tyre- so i recon the 250/273/16 would be the best option. Saying that- what tyres are you fitting to the front, as the standard tyre is hard to find? Your thoughts Wonky having a headache with his wheel
Post by Norbo on Sept 21, 2015 9:32:27 GMT 1
225 250 16 is what your looking for . so id go with the smaller of what you can get as its the closest . or I have the 225 if you need one .
