Post by wonkywheel on Jun 16, 2015 13:38:45 GMT 1
Triumph 83mm calliper conversion. Hi, looking for some feedback on this conversion. F2/R Have any of you managed to use the Triumph original hoses in this conversion, especially the crossover one? Any other advice appreciated. Many thanks
Post by wonkywheel on Jul 18, 2015 18:46:28 GMT 1
Hi I’ve just fitted a set of 83mm Triumph callipers and here’s some feedback.
The original Triumph cross-over brake line will fit yet, its tight, and after a while it might chamfer on the mudguard.
So I decided to use the cross-over line I already had on the bike, as its longer and has a good clearance over the muddy. The front bakes were using a 2 line system with a crossover line.
I got hold of a set of good condition callipers and then gently pushed out the pistons half way, with an airline, and cleaned them. You can use a bit of wood to clamp two opposing pistons while you gentle blow out the other two pistons.
I think someone, in the past, has fitted a new front master brake repair kit because bleeding went really well- it only took about ten minutes with the good old fashioned hand and basic bleed kit with a non- return valve. I’ve used a set of EBC pads (FA 236) and so far they seem sweet with no squeak.
I might use some different banjo bolts and alter the position of the lines in the near future. I'll see how it goes and seek some advice
Then a gentle test ride... Wow! What a difference! I thought that the front-end would violently dive down, yet it isn’t too bad with standard fork springs. The feedback is good and progressive.
I don’t mind that the Brazilian babe is slack in her rear end or the frame is flexing as well as the front forks- that’s half the fun! Yet shite brakes worry me, especially if some idiot pulls out on me while I’m in the band. Another bonus is I can attack the twisty bends better- happy days!
