Post by gazbeemer on May 10, 2015 11:47:33 GMT 1
Hi
When looking at my gearbox oil level i have noticed over the last week or so that it has gone up quite a bit. Not sure if its water or oil. Anybody know what the most likely culprit for this could be ?
Post by arrow on May 10, 2015 13:29:39 GMT 1
You would notice if it was water because it would go white. Most likely the oil seal on the oil pump worm shaft.
Post by gazbeemer on May 10, 2015 14:01:29 GMT 1
Oh yeh forgot to mention the bike has not been run in the last week its just been sat in the garage and it has risen. Cant remember but do i have to take clutch cover off to do this seal ?
Post by gazbeemer on May 10, 2015 14:27:25 GMT 1
Question for arrow, is the seal u mentioned the only barrier between the two stroke oil and gearbox oil ? Just wasnt sure that the 2 stroke oil reached that far. I just presumed that the seal just stopped the gearbox oil coming out. Either way it looks like the clutch cover has to come off again at the expense of yet another gasket. Lol.
Post by arrow on May 10, 2015 15:12:38 GMT 1
That seal has gear oil one side and 2T oil on the other side. Its normally pretty reliable. And yes, its the only barrier. Just for your info, the shaft has two bearings, one is a 5/16" bore in the oil pump itself and the other is a steel bush that locates in the r/h cover. On very rare occasions the bush can be missing effectively causing the seal to act as one of the bearings against the thrust of the drive gear.
Post by paulsx on May 14, 2015 22:30:41 GMT 1
Its most likey water, it wont go white until the engine has been run to mix it. The oil floats on the water. Check coolant level and if its dropping it will be the water pump seal that has given up.
Post by arrow on May 15, 2015 1:10:25 GMT 1
Its most likey water, it wont go white until the engine has been run to mix it. The oil floats on the water. Check coolant level and if its dropping it will be the water pump seal that has given up. Well, one thing is for sure, its either oil or water. Any feedback gazbeemer?
Post by gazbeemer on May 15, 2015 12:02:02 GMT 1
Yes mate as you mentioned it was the seal. Had a small nick in the rubber. All sorted now. Cheers for that
