Post by richskyrme on Apr 17, 2008 12:53:37 GMT 1
Do F2 exhaust pipes have baffles? My parts fiche does not show any, the haynes manual don't show them. I have taken the bolt out of the bottom of the pipe which I presumed held the baffle but may be just a drain plug. Any ideas, as I don't want to pull and damage the baffle if it is not mean't to come out. If the baffles are not removable, any suggestions on giving them a flush through before I refit them. Thanks. ;D
Post by mellow on Apr 17, 2008 15:51:12 GMT 1
Hi mate. The baffles as such are fixed so do not come out the bolt is a drain i filled mine with a petrol/parafin mix n gave them a good soakin/swish about. takes a while to empty out though as it gets stuck in the baffles bit but easy enough
Post by Dirtbag on Apr 18, 2008 8:25:26 GMT 1
Do F2 exhaust pipes have baffles? My parts fiche does not show any, the haynes manual don't show them. I have taken the bolt out of the bottom of the pipe which I presumed held the baffle but may be just a drain plug. Any ideas, as I don't want to pull and damage the baffle if it is not mean't to come out. If the baffles are not removable, any suggestions on giving them a flush through before I refit them. Thanks. ;D Use cheap Cellulose thinners for flushing pipes out , it does the job very thoroughly. Only the German spec YPVS's (51L) had pipes with removeable baffles
Post by richskyrme on Apr 18, 2008 10:51:56 GMT 1
Thanks, lads, thinners it is then. ;D
