Post by nimbus on Apr 4, 2015 10:30:36 GMT 1
Good day all, Having a problem cold starting (RD350LC) when she is hot no problem, but starting from cold is a bitch. I read some where that all the holes in the carb bowl must be clean so stripped them one at a time and found the one carb bowl to be blanked off while the other is not.Is this correct or do i have the wrong bowl. Attached is the blanked off bowl. Thanks Mark
Post by muttsnuts on Apr 4, 2015 10:37:30 GMT 1
the one that isn't blanked off is the one that needs to go on the choke carb, the one that is blanked off goes on the right hand (clutch side) carb
Make sure the one with the hole is clear/clean, squirt some wd40 or the likes through the jet to make sure
HTH
Post by nimbus on Apr 4, 2015 10:52:21 GMT 1
Thanks, so I had them fitted the wrong way. Will let you know how she starts when they are changed over.
Cheers mark
Post by muttsnuts on Apr 4, 2015 11:13:56 GMT 1
that would do it
Post by looey on Apr 4, 2015 11:25:28 GMT 1
Yep as Mutts says, if you've got the bowls on the wrong carbs, then you will have NO choke
Post by steeley on Apr 4, 2015 18:33:08 GMT 1
yep ,that one has caught a fair few out .
Post by nimbus on Apr 7, 2015 19:19:07 GMT 1
Thanks gents
She now start first time and my new kick starter will last a few years longer. What a great forum.
Cheers
Mark
Post by muttsnuts on Apr 7, 2015 22:20:18 GMT 1
glad to be of help
Post by Eyrey1 on Apr 7, 2015 23:28:15 GMT 1
i tought him everything he knows !
