jets
Mar 17, 2015 20:40:04 GMT 1
Post by garystaff on Mar 17, 2015 20:40:04 GMT 1
hi all what is the size of the main jet on rd 250 is it 110 because I've just put set on micron pipes on and at full throttle it bogs down just wounded if it needed up jetting thanks
jets
Mar 17, 2015 20:51:19 GMT 1
Post by muttsnuts on Mar 17, 2015 20:51:19 GMT 1
which model, C,D, E or F ?
jets
Mar 17, 2015 21:00:53 GMT 1
Post by garystaff on Mar 17, 2015 21:00:53 GMT 1
which model, C,D, E or F ? is 79 f
jets
Mar 17, 2015 21:09:52 GMT 1
Post by muttsnuts on Mar 17, 2015 21:09:52 GMT 1
um, sound a bit small to me, I need to check, but think 120's or 125's might be nearer the mark, needle needs to start in the mid positon (3rd clip), have you tried moving the needle to see if it makes a difference, also have you done a plug chop at all ?
You running the standard airbox and snorkel, or snorkel removed etc ?
jets
Mar 17, 2015 21:28:13 GMT 1
Post by garystaff on Mar 17, 2015 21:28:13 GMT 1
um, sound a bit small to me, I need to check, but think 120's or 125's might be nearer the mark, needle needs to start in the mid positon (3rd clip), have you tried moving the needle to see if it makes a difference, also have you done a plug chop at all ? You running the standard airbox and snorkel, or snorkel removed etc ? standard air box noise not done nothing to it yet just needed to find size of standed jet so i could order some bigger jets so the standed jet are 120 or 125 or is that what i should put it thanks
Post by muttsnuts on Mar 17, 2015 21:32:56 GMT 1
hang on letme check and I'll tell you for sure
jets
Mar 17, 2015 21:37:48 GMT 1
Post by muttsnuts on Mar 17, 2015 21:37:48 GMT 1
right ok, standard main jet is 115
I tend to fit 120's for a standard build these days and drop the needle down to compensate, the reason I up jet is becuase the quality of today's fuel isn't great and the ethanol in it makes the engines run a tad leaner
if you remove the snorkel (gives you a few ponies for nothing) then I go to 125's and again adjust the needle to compensate, the exact settings for your bike will vary, and ideally you want it checking/setting up on a dyno with an air/fuel ratio tester.
I'd start with 120 and the needle in the middle, if it runs a tad "fluffy" at the top end, then drop the needle one notch, so that means moving the clip "upwards" to position 2 from 3, this lowers the needle into the main jet so that it runs leaner at higher RPM
HTH
jets
Mar 17, 2015 21:39:39 GMT 1
Post by garystaff on Mar 17, 2015 21:39:39 GMT 1
jets
Mar 17, 2015 21:49:24 GMT 1
Post by garystaff on Mar 17, 2015 21:49:24 GMT 1
right ok, standard main jet is 115 I tend to fit 120's for a standard build these days and drop the needle down to compensate, the reason I up jet is becuase the quality of today's fuel isn't great and the ethanol in it makes the engines run a tad leaner if you remove the snorkel (gives you a few ponies for nothing) then I go to 125's and again adjust the needle to compensate, the exact settings for your bike will vary, and ideally you want it checking/setting up on a dyno with an air/fuel ratio tester. I'd start with 120 and the needle in the middle, if it runs a tad "fluffy" at the top end, then drop the needle one notch, so that means moving the clip "upwards" to position 2 from 3, this lowers the needle into the main jet so that it runs leaner at higher RPM HTH cheers thanks for all your help I've order 120 125 jet so when i get them are try that thanks
jets
Nov 15, 2015 21:47:08 GMT 1
Post by garystaff on Nov 15, 2015 21:47:08 GMT 1
hi all thinking of putting 350 barral on my rd 250 what would i have to change thanks
lance
Post by lance on Nov 16, 2015 21:37:19 GMT 1
Leave it alone ran well when you lent me it mate
