Post by guiri on Feb 15, 2007 5:51:57 GMT 1
has anyone done it ? the swop that is .i have got me self a cheap kr1s front end and wunderd if ill have to do a stem swop or bearings & spacers etc.
Post by alibongo on Feb 15, 2007 18:48:09 GMT 1
Have you offered it up to see how it fits? Measure the centers to see how different they are, it may just need a bearing swop.
kc104
its gripped, its sorted...
Post by kc104 on Feb 16, 2007 20:37:13 GMT 1
has anyone done it ? the swop that is .i have got me self a cheap kr1s front end and wunderd if ill have to do a stem swop or bearings & spacers etc. yep, I've done it on this one.. not really that difficult....stem is a press fit into the bottom yoke and is easily removed with a bit of heat . It then needs reducing in length cos its too long for the rd headstock. Pretty sure you can use the rd tapered head bearings but you will have to use a thin shim on the inner diameter of the lower bearing to get a good fit. Sorry I cant be more prescise with the dimensions etc but it was six years ago when I did it and I've been to bed and had a few beers since then. Good luck KC
Post by Norbo on Feb 17, 2007 10:13:51 GMT 1
I have 1 fitted to a bike aswell . A bit of a naff job realy the person who did it just fitted spacers under the top yoke to make it fit . A stem swop would look best . If i new of anyone who could do it id get my one done .
Post by hooligan on Feb 18, 2007 17:17:15 GMT 1
I can do it for ya Norbs not to dificult
Post by Norbo on Feb 18, 2007 17:54:06 GMT 1
I can do it for ya Norbs not to dificult That would be grate mate. I'll need to stip the front end of first but if i knoe you can do it i;ll drop you a line some time . Cheers .
Post by hooligan on Feb 19, 2007 21:09:03 GMT 1
No Problems the hardest bit is getting the LC stem out there welded in good and propper. And dont worry I dont charge NK rates
Post by hooligan on Feb 19, 2007 21:10:26 GMT 1
£500 should cover it )
Post by hooligan on Feb 19, 2007 21:11:05 GMT 1
Norbs sit down and breath through the paper bag its only money
Post by scott on Feb 19, 2007 22:01:59 GMT 1
lol ;D ;D ;D
Post by mellow on Feb 19, 2007 22:33:17 GMT 1
Post by hooligan on Feb 20, 2007 8:52:56 GMT 1
Not that Norbo's the tightest man on the planet or owt
z1nut
Post by z1nut on Mar 9, 2007 22:14:55 GMT 1
Not that Norbo's the tightest man on the planet or owt £500 sounds really cheap, that must be plus parts!! ;D ;D ;D ;D ;D ;D
