bump
I can see my house from here...
Post by bump on Aug 6, 2006 11:16:32 GMT 1
My bikes a converted 81 250 and still has the original rear wheel etc. Is there any point in changing to a 350 assembly, and what if any, benefits would it give ? There's nothing wrong with what's on at the mo, and everything works as well as it probably did in 81. Should I just leave well alone and save the expense and aggro
Post by pablo on Aug 6, 2006 17:44:51 GMT 1
i think the 350 cush drive may well be stronger fellah...but ive not heard of any problems with the 250 type...mebee someone else has...i'd leave it unless someone else knows better... ...the anoraks like to see the right one on them...
bump
Post by bump on Aug 7, 2006 8:06:25 GMT 1
i think the 350 cush drive may well be stronger fellah...but ive not heard of any problems with the 250 type...mebee someone else has...i'd leave it unless someone else knows better... ...the anoraks like to see the right one on them... Cheers Pablo, and you've probably made my mind up for me. I'll leave it alone, especially if it'll annoy the restos !
Post by alibongo on Aug 7, 2006 8:47:09 GMT 1
No problems with it at all, mines got a 250 rear in it and its fine.
Post by Norbo on Aug 7, 2006 23:23:09 GMT 1
The 350 one does give the chain a longer life with it having a cush drive on but you do loos a few HP with it all the racers use a 250 wheel and the 350 one is heaver if thats posable cos the 250 one is waighty anough but its more unsrung waight as well . Id stick to the 250 one ,
bump
Post by bump on Aug 8, 2006 10:47:50 GMT 1
Cheers everyone for the help. Leave it as it is then....... and see if I can find something else to b****r up instead. ;D
Post by alibongo on Aug 8, 2006 13:59:45 GMT 1
And why not?
Post by pablo on Aug 8, 2006 15:07:57 GMT 1
Cheers everyone for the help. Leave it as it is then....... and see if I can find something else to b****r up instead. ;D thats the spirit ;D
