Post by pablo on Apr 1, 2006 22:49:57 GMT 1
my gearlever has alot of play at the case end while changing gear,it looks as though there was a bush in the case at one point that the shaft ran in but this has worn out over the years...anyone know how easy it is to mod the case for a roller-bearing? anyone done it? or should i just try and fit a new bush?can you get them? or do you have to make one?come on guys...fess-up
Post by mellow on Apr 2, 2006 10:24:07 GMT 1
damn ::)thought this was a post to find a woman
Post by pablo on Apr 2, 2006 13:35:07 GMT 1
yeah i read about the bearing mod before...think it was in an old 'LC club' newsletter...gonna start digging,thought it sounded do-able,is that nylon really that workable bags? spose its worth a try...mellow,see if norbs will do a you a page for things that 'interest' you ...im sure people could find stuff to post up...have to XXX rate it though mate...maybe stick to 89.com just wondering now about the women you were expecting to see mellow.."too loose"...youve gotta mean thier morals... i hope...
Post by mellow on Apr 2, 2006 18:36:11 GMT 1
yes m8. ;D
Post by hooligan on Apr 3, 2006 20:43:12 GMT 1
Hi Pablo
I can knock you one up on the lathe, I have some nylatron its self lubricating nylon and will do the job. Post up the dimensions and I will sort it. Just got to finish the spray job first.
Post by pablo on Apr 4, 2006 0:16:20 GMT 1
i dont know how thick that stuuffs gotta be? theres a fair bit of meat on the case itself would the nylon thingy need to be pushed into the case as a solid rod then drilled out to suit the shaft?or is the nylon strong enough to be pushed into the case already drilled out to size?coz it would only be a few mill thick? what do you reckon guys?...cheers by the way hooligan
Post by pablo on Apr 4, 2006 22:03:48 GMT 1
i was thinking that...get me mate to drill it out to size on his pillardrill...how thick would that nylon need to be then...anyone got a case off the bike?...might have to wait till the weekend and pull my cover off...
Post by pablo on Apr 5, 2006 21:53:09 GMT 1
at my age...got meself with a gag an didnt realise it well spotted... ;D
Post by nuttytart350 on Apr 5, 2006 22:29:33 GMT 1
at your age........young man
Post by pablo on Apr 6, 2006 0:58:43 GMT 1
;D i delivered a package once to harry enfield...nervy little fellah he was...
Post by nuttytart350 on Apr 6, 2006 18:16:07 GMT 1
Is that your "claim to fame" then pabs
Post by pablo on Apr 6, 2006 22:49:58 GMT 1
Is that your "claim to fame" then pabs pretty much... delivered to his other half as well...cathy burke...she is tiny...couldnt stop thinking of her as perry...'hello mrs paterson,mr paterson..' 'done em all' me... paul mckenna's got an account with us...bloody nice bloke...dropped his passport off to him at the airport once..spose i'm famous really... hang out with all the 'big-nobs' ;D
Post by nuttytart350 on Apr 7, 2006 23:58:49 GMT 1
Oooooo.....can I get yer autograph... ;D ;D
Post by pablo on Apr 8, 2006 13:09:26 GMT 1
i'll have to check...i'll have my people call your people... ;D ;D ;D
Post by pablo on Apr 8, 2006 13:15:26 GMT 1
I wish they would repeat that comedy.......Harry Enfield and friends check out UK gold mate,sure its on there ...or one of them channels ;D ;D ;D...suits you sir...
Post by pablo on Apr 9, 2006 13:35:08 GMT 1
we got a freeview box upstairs...not that much on it truth be told... good excuse to find summit more interesting to do... ...like knitting...at my age... ;D ;D
Post by pablo on Apr 29, 2006 22:00:18 GMT 1
UPDATE>>>
Big thanks to Hooligan.Good as his word,he made me up a bush(two actually) on his lathe to my dimensions out of nylon.I drifted the old mullered one out of the engine case and stuffed the new one in.I asked him to do me one that wasn't ready drilled out to size,in case it deformed while fitting,a wise move it turned out.When it was wedged in good and proper,(intererence fit!) i took the case to my mates house to drill it out to size.His pillar drill wasn't exactly inspiring confidence,so i drilled it out partially and finished it using a 12mm drill bit by hand...literally,using the bit,no drill,as the nylon was cutting really easily and the last thing i wanted was another 'loose bush'.Lobbed the case back on the bike,adjusted the clutch,refitted the gearlever and linkage,job jobbed! Once more,big thanks to hooligan,who took time out from his own rebuild(looking good by the way),to help his fellow forum member... ;D ;D ;D ;D ;D
Post by mellow on Apr 29, 2006 23:58:24 GMT 1
wot a nice man ;D
Post by pablo on Apr 30, 2006 9:57:16 GMT 1
;D he's a very nice man ;D
Post by pablo on Apr 30, 2006 16:00:41 GMT 1
thanx mate...i think... ;D ;D ;D it is nice and toight tho...toight like a toiger...(goldmember)... ;D ;D ;D
Post by pablo on May 1, 2006 22:19:18 GMT 1
;D ;D ;D
Post by hooligan on May 4, 2006 17:51:04 GMT 1
Glad it worked for you mate If anyone needs any Lathe or Milling work I can make just about anything. Were's thos photos Pabs
Post by pablo on May 4, 2006 20:30:24 GMT 1
you know what mate...i was in such a rush to fit the bugger that i forgot... ...had the camera in the garage n everything... ...i'll take a piccy of the 'spare' one mate...show the boys your handywork... ;D ;D ;D...
Post by pablo on May 11, 2006 13:18:11 GMT 1
bout time... [ ] [ ] this is the old bush...i thought that someone had drilled the case out to accept this...i've since read that they are fitted as standard...but you cant get replacements...
Post by pablo on May 11, 2006 13:23:14 GMT 1
unless your mates good with a lathe... ;D [ ] [ ] [ ] mr hooligan made this little white bush out of nylon...its a lot stiffer than i thought it was...pressed it into the case and took it out to size... ;D...hooligan can make anything on his lathe,he's making me a RD500 at the moment... ;D only joking steve...thanx again mate
